took needles off gauges witout marking
  • Thread starter Thread starter what9612
  • Start date Start date Mar 5, 2008
what9612
43
Warren, MI
Mar 5, 2008
  • Mar 5, 2008
i was installing my white faced gauges and i accidentally knocked off the speedo and rpm needle... i didnt mark it or nething so i put it back on and then started my car and it said i was going 30. is there anyway to get it back to how its suppsoted to be?
SRT Handz
I tripped & fell down and cut myself & got blood
Oct 10, 2004
941
23
La Mirada, CA
Mar 5, 2008
  • Mar 5, 2008
F'd in the A
BennyBlown2v
1,233
Carmel, INdiana
Mar 5, 2008
  • Mar 5, 2008
easy. With the cluster still loose but connected to the cable, turn the car on and hold the trip reset button while you turn the key and everything - it will go into test mode, once the other needles flash or w/e cycle through till it goes to RPM, then put the RPM needle on where it is, then drive at any speed over 10mph and then look at the thing and put the needle on where it should be. Easy easy.
SRT Handz
Oct 10, 2004
941
23
La Mirada, CA
Mar 5, 2008
  • Mar 5, 2008
Lucky 99+ guys have the test feature
Turbo92PGT
746
Auburn Washington
Mar 5, 2008
  • Mar 5, 2008
All you gotta do is take the needles off. Turn the key on, and off a couple times, and with the key turned ON, put the needles are ZERO.
SaleenGT2001
Well-Known Member
Jul 18, 2005
2,811
Four Oaks NC
Mar 6, 2008
  • Mar 6, 2008
i dont think that will work on our cars
steveb24
555
wilmington, DE
Mar 6, 2008
  • Mar 6, 2008
same thing happened to me. If you have a tuner, you know what rpm your idle is at, so run the car at normal idle and press on the gauge. My speedo is still off like 6 mph, but all the other gauges you can press on with they key in the "on" position b/c you know how they should be. The car is cold, battery should be in middle, & same with oil pressure. for fuel just run it till the low fuel light is on and then press that gauge on.
still seems kinda hard to drive and press on a gauge while looking at the test thing.. idk
94GTHO
200
Richmond, Va
Mar 7, 2008
  • Mar 7, 2008
All I did was remember where they are normally when car is warmed up and idling. Then I drove beside a friend at 10 or 15mph and set cruise control on and placed the needle down.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
C
Boosted Boss 302 HP/TQ
  • coltoncaskey12
  • May 24, 2026
  • 2010 - 2014 Specific Tech
2010 - 2014 Specific Tech May 24, 2026
coltoncaskey12
C
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
