took needles off gauges witout marking
what9612
43
Warren, MI
i was installing my white faced gauges and i accidentally knocked off the speedo and rpm needle... i didnt mark it or nething so i put it back on and then started my car and it said i was going 30. is there anyway to get it back to how its suppsoted to be?
easy. With the cluster still loose but connected to the cable, turn the car on and hold the trip reset button while you turn the key and everything - it will go into test mode, once the other needles flash or w/e cycle through till it goes to RPM, then put the RPM needle on where it is, then drive at any speed over 10mph and then look at the thing and put the needle on where it should be. Easy easy.
same thing happened to me. If you have a tuner, you know what rpm your idle is at, so run the car at normal idle and press on the gauge. My speedo is still off like 6 mph, but all the other gauges you can press on with they key in the "on" position b/c you know how they should be. The car is cold, battery should be in middle, & same with oil pressure. for fuel just run it till the low fuel light is on and then press that gauge on.
still seems kinda hard to drive and press on a gauge while looking at the test thing.. idk
