TORQUE BOXES!!
lxwants12's
506
ne 1 have pics of torque boxes installed??? they are my next step.....i have heard crazy things bout them tearing on stock stangs!! couldnt imagine when i start launching at 5000 rpm with this 347 with et streets!!
yea im not sure..all i know is today im going to at least weld the seams on the stock units....im goin racing sat night and i wanna be able to haul ass and hold nothing back...i just hate leaving something on the table...
what i did was weld up my stock seams, and installe UMI performance upper and lower torque box reinforcements. I drilled mine and bolted them in then back welded em. That way I'm sure it will stay where it's suppose to.
I plan on launching my car pretty good in Factory Stock on BFG drag radials.....I'll keep you posted!
Jack
I installed my lower reinforcements last weekend. It was a really easy job to do. Drilling the holes is a piece of cake. I welded the top plate underneath where the rear seat would be, but I didn't bother to weld the bottom. It's pretty tight in there to grind and weld and I'm too lazy to go through all that.
450rwhp? i totally forgot about that...im currently making 362 and 387 torque..and by this weekend goin to be spray andadditional 125 nx wet kit and from what i hear the power they advertize is usually at the wheels!!!i should tone it down then to 100 or maybe even 75 huh??
Just know that you are on barrowed time when you are putting down more than 400 at the wheels. The block isn't the strongest out there...
If you aren't planing a motor upgrade in the near future, I'd play it safe (but that is me and I hate breaking stuff)
The lowers usually go first, really depends what control arm you have on the car.
Welding the seams is a great idea with or without the supports since they are only spot welded from the factory. The lower bracket in the main support is nearly impossible to weld properly, no matter what type of welder or how good of a welder you are. I weld the top plates (the one located under the seat) t the floor, otherwise they get bolted in. They really do not have to be welded at all......
Lowers
Uppers
Inside
so srothfuss....i should stay with 75 huh?? i hate breaking things too....i expext this motor to last...which is y its all forged the best of everything...main girdle valley girdle....cometic head gaskets..10.5 to 1 compression....high volume oile pump 8 quart miloden pan tko 600...i mean the list goess on spent lots of money and im not gonna wanna just break it to get low 11's....ill just run 75 shot...probly the safest thing to do just concentrate on suspension more
