Torque Specs
Torque Specs:
Differential housing cover bolts 24 lb-ft
Differential rear mount bolts 76 lb-ft
Differential front mount bolt/nut 52 lb-ft
Rear axle nut 251 lb-ft
Driveshaft to pinion flange bolt 83 lb-ft
Pinion brace cross-member nut 184 lb-ft
Toe link nut 35 lb-ft
Rear lower shock bolt 98 lb-ft
Knuckle to lower A-arm 85 lb-ft
Knuckle to upper A-arm 66 lb-ft (cambolt)
Ask & 'ye shall receive.
