TPS help
  • Thread starter Thread starter albino
  • Start date Start date Nov 14, 2005
A
albino
LOUISIANA
Nov 14, 2005
  • Nov 14, 2005
This should be an easy one for most except me. I need to check my TPS on my 93 and forgot what 2 wires to out of the 3 to check.
Thanks,
Tim
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 14, 2005
  • Nov 14, 2005
Try this... Currently there is some dispute about setting it at .99 volts being worth the effort, but anything less is probably OK. All you need is less than 1.0 volt at idle and more than 4.25 at Wide Open Throttle (WOT). You'll need a Digital Voltmeter (DVM) to do the job.
The Orange/White wire is the VREF 5 volts from the computer. You use the Dark Green/Lt green wire (TPS signal) and the Black/White wire (TPS ground) to set the TPS
Here’s a TPS tip I got from NoGo50
When you installed the sensor make sure you place it on the peg right and then tighten it down properly. Loosen the back screw a tiny bit so the sensor can pivot and loosen the front screw enough so you can move it just a little in very small increments. I wouldn’t try to adjust it using marks. Set it at .97v-.99v, the closer to .99v the better.
(copied from MustangMax, Glendale AZ)
1. Always adjust the TPS and Idle with the engine at operating temp. Dive it around for a bit if you can and get it nice and warm.
2. When you probe the leads of the TPS, do not use an engine ground, put the ground probe into the lead of the TPS. You should be connecting both meter probes to the TPS and not one to the TPS and the other to ground.
3. Always reset the computer whenever you adjust the TPS or clean/change any sensors. I just pull the battery lead for 10 minutes.
4. Check the procedure for your year, on my 90 I have to turn the idle screw until it just touches the tab, then insert a .010 feeler gauge and give it about one more turn. Then you adjust the TPS voltage to .98v, reset the computer. Start it up, if the idle is to low then turn the screw in until it is just right, then readjust the TPS voltage to .98v and reset the computer and start it up. The key is to adjust the TPS voltage and reset the computer whenever the idle screw is changed.
A
albino
LOUISIANA
Nov 14, 2005
  • Nov 14, 2005
thanks a ton
Thanks for takeing the time to answer in such detail. This helps a ton.
Tim
Engine Vacc leak detector
  • Creomod
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
Mustang5L5
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
TPs sensors different?
  • Creomod
  • Sep 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2026
DadLife0724
Electrical Parasitic Draw, Fuse 8
  • N8827N
  • Sep 15, 2026
Fox 5.0 Mustang Tech Sep 18, 2026
AeroCoupe
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
