tranny fluid
  • Thread starter Thread starter wildstang87
  • Start date Start date Jun 18, 2005
1 of 2 Next Last
W
wildstang87
96
  • Jun 18, 2005
need to know what type of fluid to put in my t5. i know 3 quarts but of what???
ram360
2,162
Pennsylvania
Jun 18, 2005
  • Jun 18, 2005
2.7 qts of ATF
W
wildstang87
96
  • Jun 18, 2005
type f or mercon??
J
jerryD
1,061
Gladstone, MO
Jun 18, 2005
  • Jun 18, 2005
i use type f
W
wildstang87
96
  • Jun 18, 2005
i got it off alldata, 5.0 pints of mercon for the 5speed. thanks though.
HISSIN50
34
129
Jun 18, 2005
  • Jun 18, 2005
I thought Type F was spec'd for PS and vert top pumps only. Merc is what is called for, specifically, IIRC.
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jun 18, 2005
  • Jun 18, 2005
I recall the same as you recall.
giddyup306
3,041
Jun 18, 2005
  • Jun 18, 2005
And yes they do recomend Mercon. But like I said yesterday you don't have any clutch packs to burn out in a standard trans so I guess you could get away by using other types of fluid. If you want Red Line it's D4 ATF. However GM Syncormesh is recomended by Tremec.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jun 18, 2005
  • Jun 18, 2005
I found that Synthetic ATF works best in the T5. However Mercon V is the ford transmission fluid.
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Jun 18, 2005
#10
  • Jun 18, 2005
  • #10
I think in all actuality, most of us are using Synthetics now, and most all of those meet the Mercon/Dexron requirements, so we don't even think about other fluid types like Type F. I have heard it may run better in automatics, but you obviously see an advantage to it in a manual -- what is it?
green
291
#11
  • Jun 18, 2005
  • #11
i used quaker state dextron mercon 3 in my t5.
giddyup306
3,041
Jun 18, 2005
#12
  • Jun 18, 2005
  • #12
No I see no advantage in manuals running type f. Sorry if it seems I wrote it out that way.
vikingpower
656
CWU Ellensburg, WA
Jun 18, 2005
#13
  • Jun 18, 2005
  • #13
A T5 needs ATF because of the synchros it uses, never use anything else, it'd be like not adding friction modifier to the rear end and having the clutch packs wear out
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Jun 18, 2005
#14
  • Jun 18, 2005
  • #14
Ok -- was just curious. Always looking to learn something!
HISSIN50
34
129
Jun 18, 2005
#15
  • Jun 18, 2005
  • #15
Does it really call for Mercon V? I know some of the AODE guys flush their systems and use MV as it helps with shudder and puter calibration, but do you see an issue with running the blend (Mercon V being a part synthetic) in a T5?
giddyup306
3,041
Jun 18, 2005
#16
  • Jun 18, 2005
  • #16
I think it calls for II or III.
HISSIN50
34
129
Jun 19, 2005
#17
  • Jun 19, 2005
  • #17
That is what I thought too, but I always like to check.
90mustangGT
2,773
17
89
Dallas, GA
Jun 19, 2005
#18
  • Jun 19, 2005
  • #18
Mercon V is an upgrade to II and III, unless your talking about DextronIII/Mercon.
K
KM 94 GT
124
#19
  • Jun 19, 2005
  • #19
The t5 transmission from 83-95 calls for Dex III. Looked it up in the book at work.
Kenny
maverick0716
3,924
Chilliwack, BC, Canada
Jun 19, 2005
#20
  • Jun 19, 2005
  • #20
I personally use Redline D4 in mine.
1 of 2 Next Last
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
Proper Transmission fluid for a 84nwc t5
  • Sask84gt
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
Sask84gt
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
M
Interior and Upholstery subwoofer layout planning
  • momma_mils
  • Sep 6, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 21, 2026
nickyb
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
