Tranny Fluid
  • Thread starter Thread starter foxstang9050
  • Start date Start date May 24, 2006
F
foxstang9050
158
El Doarado Hills, CA
May 24, 2006
  • May 24, 2006
Im puttin my tranny back in the car soon but before i do it i need to know how much fluid an AOD needs... and i need to know how much to put in the converter
bill302
2,131
alabama,gadsden
May 25, 2006
  • May 25, 2006
pour 1 quart of Motorcraft Mercon automatic transmission fluid into the torque converter, which will prime the front pump and get the converter filled during engine startup and a filled torque converter will hold approx. 4 quarts. and the tranny holds approx. 24.6 pints of fluid roughly 12 quarts with a dry converter.... so after all is said and i did'nt confuse you add 1 quart to the torque converter install converter and tranny and add approx 11 quarts to tranny drive and allow tranny to heat up and check fluid level and fill to proper level.....
P
Pennywise2
Banned
May 16, 2006
1,379
  • May 25, 2006
Use Royal Purple it's great stuff!
F
foxstang9050
158
May 25, 2006
  • May 25, 2006
I may sound stupid here but before this i just stayed away from transmissions so i dunno anything about them.... do i pour the 1 quart in where the input shaft goes in the converter..... and then i just as tranny fluid through the dipstick tube right?
dragnazz5.0
My "0" key d0esn't w0rk, s0 I have t0 use the zer0
Nov 19, 2005
815
mooresville, nc
May 25, 2006
  • May 25, 2006
yep, pour it in the only place it will go in the converter and than fill the tranny up through the dipstick tube
FORCED2DV8
458
Grand Rapids MI
May 25, 2006
  • May 25, 2006
Remember to check the level while the car is idling.. If you have an extra trans cooler, it will take a little more fluid
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
C
Electrical Under dash wiring
  • ChicagoMustang
  • Apr 17, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
J
1990 fox starts on starting fluid only
  • Jfox
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 15, 2026
AeroCoupe
Proper Transmission fluid for a 84nwc t5
  • Sask84gt
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
Sask84gt
