1990 convertible 5.0,switched to a manual several years ago I drove it last summer parked for the winter went to start this year and the fuel pump comes on but will not shut off it will only start when I take the intake tube off and spray starting fluid in it.I reattach the intake tube back on it it will run an idle.when i shut it off it won't start back unless i spray starting fluid again.It holds fuel pressure on the gauge.Alternator was charging 17 volts idling for some reason.My battery went dead overnight.Has a parasitic draw. I pulled the fuse out one by one and my test light didn't change any
