tranny info wanted
h82lose72
i have a 91 notch with a 302 i am going from a t5 to an auto so i was wondering what year c4 can i put in this without alot of mods. what flexplate do i use and will everything bolt right in. i am very new to the mustang so i am in the dark here. i have seen that there are differant c4 trannies, dipstick location and spline. thanks for the input.
Dipstick location is a non issue. The spline count for the input is a non issue as the torque converter that comes with the trans will be used, or you will order a converter based on the C-4 trans you get. The output shaft spine count may be different, which is no big deal as you will have to make the driveshaft longer to accommodate the shorter C-4 trans and you can get the correct yoke at that time. The thing to get right is the flex-plate. Chances are it will have to be a 157 tooth flex-plate and it HAS to be a 50 oz, imbalance flex-plate to match up the 5.0 engine balance. Otherwise the engine will have a bad vibration as the stock C-4 flex-plate is 28 oz. imbalance.
what about the starter? i have a c6 on my 87. i currently have a 93 ministarter cause with the fat starter they were breaking. went through three within a year. so whats the best starter without breaking my pockets? and what flexplate cause i think that might be my problem.
