Tranny Slipping
  • Thread starter Thread starter 19stang66
  • Start date Start date Apr 7, 2007
19stang66
689
  • Apr 7, 2007
So I finally got to drive my Stang for the first time this year. I fixed a couple of tranny leaks and replaced the rear axle seals and put new rear end fluid in the differential.
Now my problem. When I shift into reverse or drive I have to rev the engine before the Tranny will engage into whatever gear i'm in. But once I'm up to speed it doesn't slip at all and runs just fine. I never had this problem last year before I stored her. So I'm thinking it has to be something I just did recently.
Could the new rear end fluid make it slip? I used the Royal Purple Synthetic stuff. Could have I screwed something up when I removed the axles and cracked the differential to drain the fluid? I really don't know whats wrong.
enferno
418
  • Apr 7, 2007
did you check your fluid at hot idle to see if it's low or not?
19stang66
689
  • Apr 7, 2007
Right after I posted this thread I thought to myself, "Did you ever put in more tranny fluid after you fixed those leaks? Nope you didn't dumbass." I added about 3/4 fluid and she drives perfect now! I even left a lil rubber at the top of the driveway! Pegleg burnouts FTL.
P
paintballtommy
244
concord, ca
Apr 7, 2007
  • Apr 7, 2007
anything you did to the rear end shouldnt effect slippage when shiftign the transmission, the rear end is pretty much a completely mechanically driven unit whereas the tranny uses a pump and fluid pressure to get into drive reverse etc
hook up a guage to the test port on your c4 its on the right side of the tranny i believe. wait for it to warm up and check the fluid pressure. use an oil pressure test guage that can read up to a couple hundred psi the test port is a plug right in front of the shift lever on the c4 i beleive. start the car and let it heat up to op temp have a buddy watch the guage and write down the pressures in each gear. hold the brake and shift from park to revers neutral drive 2 and 1 in reverse you should have somewhere between 150 to 180 psi 90-110 in 2 or 1 60-90 in drive and 50-90 in neutral. check each gear while holdign the brake and give it at least 10 seconds in each gear then change gears.
since revers requires such a large amount of pressure to engage correctly if your pump isnt opperating right, normally you will find slippage in reverse before any other gear.
Tom
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Yesterday at 8:00 PM
Blackhawkxx
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
Rear end noise while driving low and high speeds
  • skkrtis
  • Apr 7, 2025
2005 - 2014 S-197 Mustang -General/Talk- Feb 9, 2026
Broncin491
