transmission fluid...
  • Thread starter Thread starter 90mustangfan
  • Start date Start date Oct 29, 2005
90mustangfan
93
So cal
Oct 29, 2005
  • Oct 29, 2005
I have a stock T-5 trans in my stang...It grinds inbetween shifts when the trans is cold....when it warms up it stops grinding, Im going to change the fluid, what fluid should I put in, and is there anything else I can put in to help with the grinding....I know the snycros are going but is there anything kind of fluid that will help it...Somone told me to put a teflon type of fluid, and that will help with the syncros and stuff...Is that true...
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Oct 29, 2005
  • Oct 29, 2005
ATF Dex 3
Replace the synchros soon before the grinding starts to damage the dog teeth on the gears. It will just make it more expensive.
jackchan
507
Mobile Alabama
Oct 29, 2005
  • Oct 29, 2005
ATF Dex 3
ditto!
gt40_2003wes
I did sound a wee bit gay there.
Aug 14, 2005
461
ky
Oct 29, 2005
  • Oct 29, 2005
mine does the same thing buit i think i just need a rebuild.
maverick0716
3,924
Chilliwack, BC, Canada
Oct 29, 2005
  • Oct 29, 2005
ATF. You can put synthetic in if you like...that's what I run. Don't listen to anyone who says to use gear oil or motor oil....some transmissions require those, but not T-5's.
D
Duro5341
86
  • Oct 29, 2005
^^^^^agreed.........
Either Dex III, synchromesh...........oil, and gear oil will kill your T-5
Duro
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Oct 29, 2005
  • Oct 29, 2005
That is what I was going to say! :Word:
HISSIN50
34
129
Oct 29, 2005
  • Oct 29, 2005
Some T5's do require gear oil, just not the one in an '89.
SInce it happens when cold, I would take Mav's advice and try some synthetic (not as a fix, but till you can get inside the box). It might help since it flows better cold, or it might make it shift worse. Hard to say. Worth a try IMHO.
Good luck.
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Proper Transmission fluid for a 84nwc t5
  • Sask84gt
  • Mar 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
Sask84gt
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
