transmission issue
  • Thread starter Thread starter s2hooey
  • Start date Start date May 9, 2008
s2hooey
  • May 9, 2008
All,
took my car (69 fastback) in to get some rims put on and it came back with a problem. the car will not go into park (AT) and it is like all of the gears shifted up one. for example putting it into park puts the car in reverse, putting it into reverse actually puts it into neutral, neutral into drive, etc. The guy at the tire shop says linkage but wasn't sure. of course redoing the emergency brakes (drums) in the rear has not been a priority up til now so I have a block begind it to stop her as there is no park. She still drives ok the gears and the shifter are just off. Is this a really bad issue or just an adjustment??? how much would it cost if i had t take it in??? also the stering is very loose and i am told there is n adjustment for that, any suggestions?
thanks
-dan
brianj5600
1,964
Middle TN
May 9, 2008
  • May 9, 2008
It just needs the linkage adjusted.
D
D.Hearne
11,730
south louisiana
May 11, 2008
  • May 11, 2008
Might need new motor and transmission mounts too. And be careful with it, they were known to jump into reverse from park without warning. Been there, done that. It ain't fun chasin down your car that's heading for the highway in reverse. The linkage isn't hard to adjust, it's a do it yourself operation, slightly easier to do with a freind's help. Get the rear up on jackstands, start the car, find neutral with the linkage lever on the transmission. Adjust the shifter linkage rod to where the shifter matches the position on the trasmission and install the linkage rod back in place.
rbohm
6,698
550
204
tucson,az
May 11, 2008
  • May 11, 2008
i also would start by checking the mounts for condition, if one is suspect or bad replace the lot of them, and the adjust the trans linkage.
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
C
Shifter lever arm issue
  • chris1993
  • Jan 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 24, 2026
Rcdgl
R
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
