Transmission just died...
  • Thread starter Thread starter ram360
  • Start date Start date Jul 29, 2005
ram360
2,162
Pennsylvania
Jul 29, 2005
  • Jul 29, 2005
Took the car for a ride today. I really didn't even get on it more than half throttle and it's now making some aweful noises in 4th and 5th gear. It goes away if I push the clutch in which eliminates the possibilty of a rear end prob. It's not like it's shaking or anything just making a grinding noise or sounds more like something is rubbing. I thought something was rubbing under the car but it's not. BTW it's a 91 T5. I'm thinking it's going to go soon. Just dunno If I should even drive the car anymore w/ the trans the way it is, don't want to damage anything else. BTW if anyone in or around NE PA is looking to get rid of a decent T5 lemme know.
88stangmangt
2,332
Stafford,VA
Jul 29, 2005
  • Jul 29, 2005
4th and 5th.....hmmm sounds weird.
ram360
2,162
Pennsylvania
Jul 29, 2005
  • Jul 29, 2005
1-3 noise at all. Just 4th and 5th. but it still goes in to gear pretty good and doesn't pop out. Fluid was just filled too.
ram360
2,162
Pennsylvania
Jul 31, 2005
  • Jul 31, 2005
Took it for another ride today and maybe it doesn't apperar to the trans after all. Maybe I jumped to conclusions a little to quick Sounds like noise is further back and it sounds like something is scraping when every now and then when driving when there is a small dip in the road. I looked around an nothing apprers to be loose. I mean the car is extremely low but I'm starting the suspect the rear sway bar at this point. I'll have to crawl under and see if I can fine some bare metal spots on whatever was rubbing.
Rick 91GT
Mustang Master
95
99
PA
Jul 31, 2005
  • Jul 31, 2005
If you need a tranny I have a fresh world class T-5 Z.....
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 31, 2005
  • Jul 31, 2005
Look for scratch marks on the driveshaft. The Ebrake cable may be dragging when you hit a bump.
ram360
2,162
Pennsylvania
Aug 6, 2005
  • Aug 6, 2005
I looked it over and I found that my driveshaft loop was rubbing the driveshaft when I hit a bounce. I had some exaust work done and the guy took the liberty of bending my driveshaft loop which created the rubbing issue. Looks like that solved the problem.
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
Engine Light throttle miss
  • Dontknowchit
  • Jul 7, 2025
Fox 5.0 Mustang Tech Jul 7, 2025
AeroCoupe
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
