Transmission leak
  • Thread starter Thread starter kpack5982
  • Start date Start date Jan 30, 2006
kpack5982
Yeah, it was pretty stiff, but eventually a buddy
Jul 13, 2005
325
Granger, IA
Jan 30, 2006
  • Jan 30, 2006
I just looked under my car today to find tranny fluid on the garage floor. I got underneath and found it to be leaking out of the shaft attached to the driveshaft. do i have to replace the shaft or is there something in the tranny that would fix that or what are your opinions on what needs to be done or what I should do?
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Jan 30, 2006
  • Jan 30, 2006
Change the seal at the rear of the tailstock. I think it can be done without taking the tranny out just remove the drive shaft.
carbed87
215
  • Jan 30, 2006
exactly, just remove the driveshaft, pop it out with a screw driver, and replace. i gotta do that to my trans am, im just too lazy to do it lol.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jan 30, 2006
  • Jan 30, 2006
Due to the age of the car/trans, replace the seal first, but if the problem happens again, you have other problems. Auto or manual? Are you sure the leak isn't blowing back from the top where the shifter bolts down? Many people put a new shifter on their car and don't put any sealant there and the trans fluid leaks out.
87_stang
131
Tonganoxie, KS
Jan 30, 2006
  • Jan 30, 2006
I would suggest the seal in the rear. Very easy to swap out. Cheap also.
L
lmarinukjr
75
  • Mar 9, 2006
not to hi jack this but i have the same problem i did replace my shifter with no sealor but i dont see a leak from the top i did just replace the tailshaft seal the is very little play in the output shaft. will there be a trail if im leaking at the shifter
kpack5982
Jul 13, 2005
325
Granger, IA
Mar 9, 2006
  • Mar 9, 2006
Really doubt it would leak at the shifter, never had anyone I know have that happen, butif the car is stationary and you notice a puddle underneath it i'd throw that out. Don't know if it helps, but when I put the new seal in, didn't get it in right or something cause when I took the driveshaft out and hooked everything back up, haven't had a problem since
L
lmarinukjr
75
  • Mar 9, 2006
its not just when its sitting if i drive it for a long time or really hard it drips onto the converter and smokes pretty bad
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Mar 10, 2006
  • Mar 10, 2006
^ I had the same problem when I put my new shifter in the 86 GT one time... turns out I was so hard on the tranny I cracked the casing
Just jack it up, clean it, drive it, jack it back up and look with a flashlite
L
lmarinukjr
75
#10
  • Mar 13, 2006
  • #10
still leaking no clue whats going on
T
Thordic
41
Cedar Grove, NJ
Jun 23, 2006
#11
  • Jun 23, 2006
  • #11
Just for the record, what would that seal be called? I'm having a similar problem and if I start looking around "for that seal between the trans and the drive shaft" it might be a pain to locate
legalize420
1,541
South Florida
Jun 23, 2006
#12
  • Jun 23, 2006
  • #12
i thought it was called a tailshaft seal. advance auto has it as a mainshaft seal. part #S7692S. i changed mine last week.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
M
Drivetrain T5 Transmission Leak at Tailshaft
  • MDrisc
  • Jun 17, 2025
Fox 5.0 Mustang Tech Jun 18, 2025
AeroCoupe
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
