  • SN95 V6 Mustang Tech
Transmission Range Sensor ...
  • Thread starter Thread starter Alex96stang
  • Start date Start date Aug 17, 2011
A
Alex96stang
17
Chula Vista CA.
Aug 17, 2011
  • Aug 17, 2011
Hi
its been a long time since i posted on this forum
so i just wanted to ask to see if you have had the same problem
my car is a 96 v6 automatic
and on occasions the starter wont kick in when i turn the ignition key
and i have to wiggle the the shifter or move it to neutral in order to start the car, other than that the car has no problems what so ever.
I have narrow it down to the neutral safety/range sensor.
what other symptoms does the range sensor could cause other than the no starter kicking in
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Aug 17, 2011
  • Aug 17, 2011
I don't understand your question. Are you asking how to narrow it down to the DTR? Or are you asking if it's OK to ignore it?
If the DTR works in neutral but not in park, likely there is an adjustment issue. Ford makes a special tool to align the DTR. Some ppl have been able to adjust it without the tool. YMMV.
A
Alex96stang
17
Chula Vista CA.
Aug 18, 2011
  • Aug 18, 2011
I have already narrow it down to the DTR
so the question is:
what other symptoms could the range sensor show besides the no starter on park
i can start the car in pork or in neutral that's not a problem
the thing is that i don't want it to give up on me before i change it that's why i asked for the other symptoms of a range sensor malfunction other that the ones stated on my op
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Sep 13, 2026
Mcmahst
Resolved Crank no start after engine swap
  • biggrim
  • Sep 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 12, 2026
biggrim
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
M
85 mustang 5.0 cranking in run position
  • Mamaclean
  • May 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 1, 2026
General karthief
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
