  • SN95 4.6L Mustang Tech
Transmission Slipping
  • Thread starter Thread starter nc88wolfpack
  • Start date Start date Jan 20, 2010
N
nc88wolfpack
  • Jan 20, 2010
After changing the ball joints this afternoon (97, 5Spd), I crank the car and put into reverse. When I started letting out on the clutch the shifter knob moved horizontaly to the left. So now my reverse is where 1st gear normally is. When I put the car in first, the shifter moves back to the right a little. Im pissing the in dark, but maybe a loose motor mount or transmission mount bolt? HELP!!
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Jan 21, 2010
  • Jan 21, 2010
Sounds like you need someone w/a mirror to watch the transmission while you move to confirm, is it making any un-natured noises, need more info so I can look up some stuff.
patman0911
2,287
Tuscaloosa, AL
Jan 21, 2010
  • Jan 21, 2010
Yeah, you'll have to get under there and take a look but a busted trans or motor mount is your likely culprit - just have to figure out which.
The trans & motor are going to want to twist in the opposite direction the driveshaft is turning which is why the shifter moves one way in reverse and the other in forward gears.
N
nc88wolfpack
  • Jan 21, 2010
As far as any noises or anything, it hasnt made any of of the ordinary and no grinding or such. The shifter just moved. Thanks for the replys, i was figuring on it being a mount, just needed some reinforcement before I get under there. Hopefully this afternoon i will have time to get underneath it and check it out. Ill def update you guys on whats going on.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jan 21, 2010
  • Jan 21, 2010
Use a prybar to diagnose this not engine torque especially if anyone is under the car.
F
fromadig91
95
  • Jan 21, 2010
Gonna go with kilgore on this one, use a prybar.
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
K
TKX Transmission Shifting Problem
  • KWC156
  • Jun 23, 2025
  • Other Auto Tech
3K
Other Auto Tech Jun 13, 2026
427nostang
