  • SN95 4.6L Mustang Tech
Transmission whine?
  • Thread starter Thread starter IcedTea
  • Start date Start date Jan 27, 2012
IcedTea
12
  • Jan 27, 2012
What is the whine auto transmissions make at wot in the high rpm range (5-6k) when they are about to shift? I've heard some autos that do this some that do not. Here is an example
BurningRubber
1,865
24
58
Jan 27, 2012
  • Jan 27, 2012
Might not be the transmission. Any accessory going bad on the front of the engine can whine... such as the PS pump, alternator, waterpump, etc.
wveil3v
28
  • Jan 28, 2012
Sounds pretty normal to me, I had an 04mach that made the same type sound but was more noticeable because of the shaker hood, esp. in passing gear .
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Jan 28, 2012
  • Jan 28, 2012
From my experience, Power-steering pumps and Water-pumps usually squeal, b/c of bearings losing there outer coating through wear and tear. But, rack and pinion will whine especially if you turn the wheel all of the way to the left and to right.
O.p. check your Transmission's fluid level and keep track on hard shifting is about all you can do. Unless you can tear apart you cars auto-transmission and put it back yourself.
Honestly, it sounds as if your Auto is gonna give sometime in the very near future. Sounds as if the pinions and such gears are grinding ever so lightly, just enough to indicate wear. So, wide-open throttle pulls are not good your auto as we speak especially if it only does that at such time.
Time for an Auto rebuild.
IcedTea
12
  • Jan 29, 2012
Sounds logical, but I would have figured it would have kicked the bucket by now. Bought the car at 55k miles has almost 73k now(drive it everyday) so i've done alot of wot pulls and such and it has always made that noise at high rpm. I do check the fluid often and it has no bad signs (doesn't smell and is redish/pink). I find alot of auto mustangs on youtube that make the same noise as far as I can tell.
If it was an accessory I would hear it at times other then high rpm at wot right?
IcedTea
12
  • Jan 29, 2012
Did it ever have any tranny issues?
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
Jan 30, 2012
  • Jan 30, 2012
Some car's transmission can have a quirk or two and last a very long time with regular fluid changes, and some never have any issues and quick all of a sudden.
All I'm saying really is, don't be surprised when the auto does give, wish my car's transmission gave me a warning.
IcedTea
12
  • Jan 30, 2012
Thanks for your help, hopefully If I take care it will last awhile longer. Heard the 4r75w is a stout tranny. I have never been able to find an answer as to why so many autos make this noise. Although it could very well be grinding, and about to die on me lol.
K
4r70w transmission problems
  • Kiddmustang
  • Jul 14, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 21, 2026
squeak93
D
Drivetrain Using a 98 Cobra T45 in a 03 GT Auto
  • dylan9075
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
dylan9075
D
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Drivetrain Decode this Tremec tag?
  • Scott_S
  • Jul 25, 2026
Fox 5.0 Mustang Tech Jul 25, 2026
