  • 1994 - 1995 Specific Tech
Transmission wiring harness "help"
  • Thread starter Thread starter drewzx3
  • Start date Start date Mar 24, 2007
D
drewzx3
411
Louisiana
Mar 24, 2007
  • Mar 24, 2007
How many different plugs is the T5 wiring harness suposed to have? Where do they all go? I was looking at my wiring harness and I only see two places for them to go to the transmission.
D
drewzx3
411
Louisiana
Mar 25, 2007
  • Mar 25, 2007
ttt
mustanggt94
642
Indianapolis, IN
Mar 26, 2007
  • Mar 26, 2007
For 94/95 they have just the Speed sensor (two wire flat harness) and the reverse sensor (two wire round) and they both plug in on the drivers side of the transmission.
That should be all there is to it.
D
drewzx3
411
Louisiana
Mar 26, 2007
  • Mar 26, 2007
Mine has 5 plugs on it total and the 2 that plugs onto the tranny fits and the main plug fits so if everything works it should be alright then huh?
gunmetal5.0
144
Chico, CA
Mar 26, 2007
  • Mar 26, 2007
Didnt I answer this in another thread?
D
drewzx3
411
Louisiana
Mar 26, 2007
  • Mar 26, 2007
nope
gunmetal5.0
144
Chico, CA
Mar 26, 2007
  • Mar 26, 2007
Hmmmm
Today, 04:51 PM
Also you have to wire in the neutral safety switch. Non 5 speed cars have it on the harness too. You plug it into the tranny. Also you need to hook up the reverse light switch, also on the tranny. I went to a wrecking yard and got the small harness that connects to the tranny off a 5 speed. Make sure you just go ahead and take the dash out, I did and it made my life easier. The driveshaft was the same length also. Make sure you have good u joints and a good rear seal in the tranny while you're at it. I had to do it afterward. 25 dollars total. Good luck =)
You're welcome
Electrical V8 swap no power to anything
  • Bullittsmith
  • Sep 12, 2026
1994 - 1995 Specific Tech Sep 15, 2026
Mcmahst
WTB Looking for wiring harness parts 95 gt
  • 74delta
  • Jul 8, 2026
  • Want to Buy
Want to Buy Jul 9, 2026
74delta
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
Electrical/engine bay harness questions
  • djj62478
  • May 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 6, 2026
djj62478
E
V8 Swap in a 95 - Wiring Help Needed
  • electricityisnotmyfriend
  • May 13, 2026
1994 - 1995 Specific Tech May 21, 2026
