Transmission
  • Thread starter Thread starter 87Mustang351
  • Start date Start date Jul 2, 2006
87Mustang351
220
Canada, Nova scotia, Cape Breton
Jul 2, 2006
  • Jul 2, 2006
I have recently before i put my car on the road had my guts of my tranmission put in another casing because of a crack in mine. and ever sence they put it in my car now does 2 New FANTASIC things 1: pop out of first gear on a up hill slope,only way it will not pop out is if im still moving and put it in first, and 2: a bad viberation all through my car...like seriously at 120 KPH if i sat a girl on my shift she wouldnt last 10 seconds on there....i really need to know if something is put in the trans wrong will it make a viberation?
Bladez5_0
460
Goose Creek, SC
Jul 2, 2006
  • Jul 2, 2006
Have you tried adjusting your shifter stops to allow more throw to set the tranny deeper in the gears? As for the vibes. Are you sure that you have the driveshaft in the correct position instead of 180* out maybe?
Mustang5L5
Mod Dude
Feb 18, 2001
43,377
18,123
224
Massachusetts
Jul 2, 2006
  • Jul 2, 2006
Did it do this before you swapped cases?
SOunds like something wasn't set right
87Mustang351
220
Jul 3, 2006
  • Jul 3, 2006
no it didnt do it before but sence then i have tryed the driveshaft i drove it home with and such what do you mean 180*? can you explian some more?
tthis might be the problem the vibes right up thrugh the middle of the car
thanks
Todd
Bladez5_0
460
Goose Creek, SC
Jul 3, 2006
  • Jul 3, 2006
The driveshaft of the car is balanced to be installed a certain way. You can reinstall it 180 degrees out of normal position which causes vibrations. Other people have had issues with keeping the stock driveshaft and moving up to 3.73's and 4.10's. They'll have vibrations that they can't get rid of until they got an aluminum driveshaft. Not sure if it's an issue with the stock driveshaft's balance or not.
87Mustang351
220
Jul 3, 2006
  • Jul 3, 2006
well i had a stock drive shaft in and i have 4:10s and it never shook before...so what your saying basically is try the drive shaft in another set of holes ? a new set of 4 i mean
Bladez5_0
460
Goose Creek, SC
Jul 3, 2006
  • Jul 3, 2006
Firstremove the driveshaft and reinstall it a half turn from where it is now. I think you can only install it 2 ways but I'm not sure. On mine you can see the outline in the surface rust from where it was installed at the factory.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 3, 2006
  • Jul 3, 2006
There should be a yellow paint mark on the D/S and axle flange. Match the two up and you will be lined up to factory specs.
With 3.55 or higher gears, the stock D/S balance may not be good enough to keep the vibrations down to an acceptible level. Balancing the driveshaft can fix that. A new FMS aluminum D/S is a good fix, but expensive - about $250 unless you can get an Ebay bargain.
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
D
sad day
  • davecobra2
  • Jul 13, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jul 22, 2026
davecobra2
D
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
M
Drivetrain 5 speed will not shift at all
  • Meadecomustang
  • Mar 4, 2025
Fox 5.0 Mustang Tech Jul 29, 2025
AeroCoupe
