Tri-State Cylinder head modifications
Triple White 91
Hello everyone,
Just wonder if the modifications that Tri State Cylinder head has made to the gt40p heads would help or hurt a stock motor in terms of 1) drivability, 2) performance. I spoke to a rep. and he said that the larger valves allow the head to breath better. He also said that the heads are milled between 3 and 5 thousands. I asked if that would create allignment problems to the intake manifold and he said no. Was he correct? The specs are as follows:
Ford GT40P Remanufactured
289/302/
60cc Combustion Chamber
Pedastall Type Rockers Used
Positive Oil Control Seals
5 Angle Valve Job
Stainless 1 Piece Swirl-Polished Under-Cut Stems 1.940” Intake Valves
Stainless 1 Piece Swirl-Polished Under-Cut Stems 1.540” Exhaust Valves
AWSF-32C Spark Plug
Springs Good to .550” Lift, (Hyd. Roller) *check cam manufactures specs for compatibility*
(129 psi @ 1.800” / 280 psi @ 1.300”)
100% Satisfaction Guaranteed!
They are $598.00 a pair. What do you think? Opinions please.
Thanks for replying. Where abouts in the rpm range did you notice the power gains? Personally, I'm looking to maintain as much bottom end torque as possible as this is a street car/daily summer driver. I want to keep the stock gears because of the high gas prices.
ok well im the one mouse is talking about i had put a set of there 190 heads on a stock short block with a tfs1 cam in it and a holley systemax2 intake wit tbpdy and headers and it stayed really strong till 6 grand and it made really goow power down low like 2000 rpm it pulled good and strong , now i allso have a set of there bigger 210 runner heads i used on my 347 and they are nice heads for the price tag just make sure if u have a cam that u give them the specs for it so they can set you up with the rite vavlesprings
Thanks once again for the reply. Your information on the topic is very helpful. Just wondering if the stock HO cam would work with the 190 heads and an edlebrock performer 5.0 manifold, headerds, 70 mm mass air, 65 mm tb and 1.6 rockers. I've been doing some reading and in previous posts people have been putting the stock cam back in to regain drivability. The change in performance (increase or decrease)was not that noticable hence some guys liked the stock cam. What do you or anyone else think?
The ONLY issue is the valve size!! when EVER you install a head with the valves larger than the 1.85 ( Ford stock pistons are notched for only the 1.85 size) you HAVE to be careful!! Be sure to check piston to valve clearance!! cool?? we have seen a 1.900 hit out side the valve pockets on stock pistons!! FYI..yes?
Just me..............................
THUMPER
Thank you 88mouse for your input on the cams and thank you Thumper460 for the info on the valve size piston clearance issue. I would hate to make more work for myself because of a lack of information. There are few to no people that I know of in my neck of the woods that can answer these types of questions because of the age of the car and population size. I really appreciate the info.
Sorry about that. I forgot that we had to notch the pistons. We just used a dremal tool with the little carbied bit.
