  • 1994 - 1995 Specific Tech
Trick Flow
  • Thread starter Thread starter tderrick
  • Start date Start date Oct 17, 2009
T
tderrick
312
Oct 17, 2009
  • Oct 17, 2009
I will be rebuilding my engine soon and I'm looking at the Trick Flow Street
kit. What is the price on something like that.
intake, cam , heads... all the little parts ....you know the one....
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Oct 17, 2009
  • Oct 17, 2009
Good kit. You can get the price off of Summit. Don't get too lazy here.
Kurt
Venom351R
4,548
41
98
MAINE
Oct 17, 2009
  • Oct 17, 2009
That kit is about $2,400 from summit.
sgarrelts01
133
Niles, Michigan
Oct 18, 2009
  • Oct 18, 2009
To get the 350 or 360hp out of that kit i believe you have to have your block bored. On the trick flow website it says it was tested on a 306 i think.
edit- I looked it up but i can't seem to find where it says that. I swore i read that about the kit. oh well looks like i am wrong. Still a good kit imo.
302GTS
If you need herpes, I'm your man!
Apr 20, 2009
481
Largo, FL
Oct 18, 2009
  • Oct 18, 2009
You're right! They got rid of that part. It was tested on a 306 with some fuel mods I believe.
The Trick Flow kit is great, IMO, and is what I plan on doing once the money comes in, or my girlfriend decides to be really nice. With the Trick Flow kit, and a solid tune, with possibly switching to 24 lb/hr injectors with calibrated MAF, I've heard that you can expect around 300 at the wheels. May not seem like a whole lot but, for a top end rebuild that comes with everything needed, it's not bad at all! Throw a 100 shot on that and call it a day.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Oct 18, 2009
  • Oct 18, 2009
The difference between a 306 and 302 will be negligible.
Kurt
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 18, 2009
  • Oct 18, 2009
For the money you can piece together a better kit. I had that kit years ago before it was offered as a kit. It works fine for the average enthusiast but you can piece better stuff together.
The O.G.
145
witch city,mass
Oct 18, 2009
  • Oct 18, 2009
I agree.
F
Fordman1995
28
  • Oct 18, 2009
The AFR Heads is far beter heads!
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Oct 18, 2009
#10
  • Oct 18, 2009
  • #10
How do you figure? The AFR 165 is an entry level head, with stock port heights and valve angles. Anything bigger with an AFR, and you have to notch the pistons. The Trick Flow you can run a bigger valve and a bigger valve due to the inproved valve angles.
Kurt
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Oct 18, 2009
#11
  • Oct 18, 2009
  • #11
Kurt
opcorn:
Grady
Stang D
122
Quad Cities, Iowa
Oct 18, 2009
#12
  • Oct 18, 2009
  • #12
Stop hogging all the popcorn Grady.
The O.G.
145
witch city,mass
Oct 19, 2009
#13
  • Oct 19, 2009
  • #13
Kurt
Does the larger valve of the tfs have a negative effect on cam choices?Speaking stock stuff.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Oct 19, 2009
#14
  • Oct 19, 2009
  • #14
Not really. It generally gives you more power with available cams. I remember the good old days when we used to notch the pistons while they were still in the engine, and still in the car. I think Lunati still sells the notching kit, although that isn't as common of a practice now.
Kurt
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
