  • SN95 4.6L Mustang Tech
Trouble Code P0442
  • Thread starter Thread starter CoastiebumGT
  • Start date Start date Mar 1, 2011
CoastiebumGT
10
League City, Texas
Mar 1, 2011
  • Mar 1, 2011
I just installed O2 sensor eliminators, check engine light went off, it's been off for a few days now, then it came back on. I got it checked with a code reader and got the code P0442 (Evaporative emission system) small leak/no flow condition. I've checked all lines for vacuum leaks with brake cleaner, checked my fuel cap and took out the O2 eliminators to see if that was it. No joy. Anyone have anything else I should check or replace? Engine still runs fine and haven't lost any power, the light came on after I stomped on it pretty good, but no change in engine performance.
Tim
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Mar 1, 2011
  • Mar 1, 2011
I give up. What model year are we dealing with?
This DTC can be a real PIA. My suggestion. Reset the code and see if it comes back.
If it does come back, focus on the evap lines around the gas tank. Inspect the filler neck for rust out.
joshjwc9
1,095
17
39
Palm Harbor, FL
Mar 1, 2011
  • Mar 1, 2011
Just went through a p0455 on my car. Was a hairline crack going into the charcoal canister right back by the gas tank on the passenger side, extended some hose and fixed it just like that.
Stan Weiss
347
Philadelphia, PA
Mar 2, 2011
  • Mar 2, 2011
Check the gasket where the filler neck goes into the tank.
Stan
trinity_gt
3,125
81
99
Canada
Mar 2, 2011
  • Mar 2, 2011
They're not always easy to find but if you can lay your hands on one, a "smoke tester" can often prove very handy for finding evap system leaks.
I agree with checking the tank seal at the filler neck. If it's not that, try to put smoke into the system and see where it's leaking out. Here's an example of it being done on a Jeep:
YouTube - 03 Jeep Evap P0442
GDawg
1,469
Nevada
Mar 2, 2011
  • Mar 2, 2011
Nice link Trinity!
CoastiebumGT
10
League City, Texas
Mar 5, 2011
  • Mar 5, 2011
So I took the vapor canister off and opened it up, in the little box where the plug goes in was all caked up with dirt and the foam was all tore up, so I put some new foam (whatever it is) in it and erased the code, guess we'll see if that works. Thanks for the replies. Got new pics up of the car with the new rims on it and drag radials.
Tim
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
P
Repeated P2004 DTC trouble code with no apparent symptoms
  • poehitman
  • Mar 11, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 12, 2026
poehitman
P
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
