Trouble starting when Hot!
  • Thread starter Thread starter Kdubslugga
  • Start date Start date Jul 23, 2010
Kdubslugga
1,515
Akron, OH
Jul 23, 2010
  • Jul 23, 2010
On cold start up, car starts up and idles perfect sometimes after a nice long cruise the car wont start back up. Key on the volts are right at 12 but it sound likes a dead battery, it wants to turn over but not enough juice it seems like.. I tried using jumper cables to jump it, it does nothing. Sometimes when im trying to crank the motor over the starter keeps slowly cranking even with the key out. Car cools down it starts right up no problems. I really dont think its battery or alternator related. Also when its hot i it actually fires up, the idle is very erratic for 20 sec or so?? Only thing ive found so far is the o2 ground wire that bolts to the back of the head was broke. I though no doubt this will fix it, but it didnt. I didnt ground to the head i used that long 2 inch stud thing that on the firewall, is that a good enough ground? Ive also recently done an EGR delete which im thinking of taking off, see what that does!!
HISSIN50
34
129
Jul 23, 2010
  • Jul 23, 2010
Two things I'd consider are deficient battery cables (they get resistive as they get hotter) or a bad starter (esp if you happen to have LT's).
cjrpony
439
West Michigan
Jul 23, 2010
  • Jul 23, 2010
+1 on the bad starter. Do you have one of the old style starters or the newer mini starter? The old style will do that when they get hot, especially if you have headers. The heat causes more resistance in the starter (As Hisson50 said about the cables) which causes it to turn slowly. The newer style mini starters are not affected by heat as much because they use permanent magnets. I had this problem on a previous car, and upgrading starters completely solved it.
NIKwoaC
中國製造
5,525
943
214
Chengdu Province
Jul 23, 2010
  • Jul 23, 2010
Before you waste time trouble shooting or replacing anything, take your battery into a parts store and have them test it. I chased hot start issues for a LONG time, replaced the starter, replaced the cables, re-did all the grounds, even wrapped the headers with thermal wrap. ALL of this, because my battery seemed fine because it was reading 12 volts with the engine off, ~13V engine on. Finally checked the cranking voltage, which was like 8-9 volts or something. Somehow it was managing just enough power to start the car when it was cold, but not hot. Took the battery in, and sure enough, it was dead as could be. Replaced it with a new one and the car hasn't had a single issue since.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jul 23, 2010
  • Jul 23, 2010
Definitely have the battery checked out first. If it checks good, be prepared to do some voltage drop testing to find any bad connections or bad cables.
1.) Will the car start if it is jumped? Then clean battery terminals and check battery for low charge and dead cells. A good battery will measure 12-13 volts at full charge with the ignition switch in the Run position but without the engine running.
A voltmeter placed across the battery terminals should show a minimum of 9.5-10 volts when the ignition switch is turned to the Start position and the starter engages or tries to engage. Less than this will result in a clicking solenoid, or slow cranking (if it cranks at all) or a starter solenoid that sticks and welds the contacts together.
Most auto parts stores will check your battery for free. It does not have to be installed in the car to have it checked; you can carry it with you to the auto parts store.
The battery posts and inside of the battery post terminals should be scraped clean with a knife or battery post cleaner tool. This little trick will fix a surprising number of no start problems.
The clamp on with 2 bolts battery terminal ends are a know problem causer. Any place you see green on a copper wire is corrosion. Corrosion gets in the clamped joint and works its way up the wire under the insulation. Corroded connections do not conduct electricity well. Avoid them like the plague...
A voltmeter is handy if you are familiar with how to use it to find bad connections. Measure the voltage drop across a connection while trying to start the car: more than .5 volts across a connection indicates a problem.
See Automotive Test Tools for help for help troubleshooting voltage drops across connections and components. .
2.) Check the battery to engine block ground down near the oil filter, and the ground behind the engine to the firewall. All grounds should be clean and shiny. Use some sandpaper to clean them up.
3.) Jump the big terminals on the starter solenoid next to the battery with a screwdriver - watch out for the sparks! If the engine cranks, the starter and power wiring is good. The starter relay is also known as a starter solenoid.
Kdubslugga
1,515
Akron, OH
Jul 24, 2010
  • Jul 24, 2010
Ok thanks guys ive been away for a few days sorry for the slow response, but im definetly gonna have my battery checked out this week. I hope thats all it is!!
Kdubslugga
1,515
Akron, OH
Aug 2, 2010
  • Aug 2, 2010
Had my battery checked, its fine. Starter is shot...I got the old one out in like 20 min, getting the new one back in with long tubes in the way NOT FUN!!
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
  • dan50
  • Jul 18, 2026
dan50
