Troubleshooting leaks
Adverse2Change
340
Raleigh, NC
Any of you ever have those fluids leaks you just can't seem to stop? I replaced my thermostat this weekend and ran into that problem. The actual install should have taken under 30 minutes to do as it is rather simple and straightforward, but of course as my luck would have it I run into a leak. It was pretty heavy at first, but I disconnected again, reseated the gasket, thermostat, & housing and added some more rtv silicone. The leak improved to a small drip every 10 seconds or so. Absolutely freakin' annoying! I ended up leaving it at a shop for the weekend, so its probably a mess under the hood now.
Are there any common things to look for when you have leaks of this nature? Can over tightening bolts actually cause more leaks?
Yes, overtightening can cause leaks and the dreaded bolt break. Cheap replacement parts can also attribute to a leak. I remember changing a water pump on my old 280ZX and it leaked like crazy. We did everything you mentioned and it still leaked. Found out that the part we replaced it with was the problem. We had bought the part at Chiefs Auto Parts when they were still in Dallas. We went to another parts store, cant' remember the name and the replacement part worked fine. Try a thermo from another parts store and see if that helps. Also get a new gasket too. And possibly a torque wrench so you don't overtighten. I remember one of my friends over tightened a bolt while replacing a exhaust manifold. The head of that bolt went snap....I was like..."Later dude..have fun with that."
I know a lot of guys use rtv silicone like that but I won't anymore. It can come loose and plug up your cooling system (I've had it happen). Get some 'Right Stuff', it won't come loose and you won't have any leaks.
