  • 1994 - 1995 Specific Tech
Trunk Lamp
  • Thread starter Thread starter Adam706
  • Start date Start date May 30, 2009
Adam706
25
Columbus, GA
May 30, 2009
  • May 30, 2009
i can not get my luggage/cargo lamp to work... tested with a new bulb, all fuses are good, all other lights work. when i open the trunk there's nothing. i'm hoping some of you guys have other things i can check. like is there some kind of switch when the trunk is opened? thanks, Adam
HISSIN50
34
129
May 30, 2009
  • May 30, 2009
Check in/out continuity at the tilt switch in the trunk lid.
Y
yukisho
Banned
Apr 4, 2009
44
Saint George, Utah
May 31, 2009
  • May 31, 2009
I had the same problem. There is a switch like thing. Mine was bad. Now my trunk latch has stopped working lol.
toyman
1,944
54
79
Vernon BC
May 31, 2009
  • May 31, 2009
The switch while normally not serviceable might be fixable. Mine was stuck in the on mode and was the source for a drain on the battery. Carefully drill out the rivit then carefully open up the switch. Clean all the parts with electrical contact cleaner and reassemble. I couldn't find a rivit long enough so I used a small bolt and nut to hold everything together. It's been working fine since the repair. I did this as the replacement switch was either no longer available or very pricey.
Adam706
25
Columbus, GA
May 31, 2009
  • May 31, 2009
where's this tilt switch at? is that the little black box near the latch release?
Y
yukisho
Banned
Apr 4, 2009
44
Saint George, Utah
May 31, 2009
  • May 31, 2009
What I did was go to a junk yard, barter with them about the cost or find a smashed one, and use a grinder and cu the switch out, then weld it to yours(cut yours out too).
Adam706
25
Columbus, GA
May 31, 2009
  • May 31, 2009
crap i might as well just straight wire and throw in the on/off switch.. lol
Y
yukisho
Banned
Apr 4, 2009
44
Saint George, Utah
May 31, 2009
  • May 31, 2009
Would be a great idea. I thought of doing that and adding more lights in the deeper part of the trunk since the one light doesn't light the whole trunk up. That may be my next project.
HISSIN50
34
129
May 31, 2009
  • May 31, 2009
It would be easy to retrofit a mercury switch or use a pin switch. A master on/off switch is a good idea if one fears the new switch might stay on due to lack of adjustment.
Adam706
25
Columbus, GA
May 31, 2009
#10
  • May 31, 2009
  • #10
well i opened the tilt switch and cleaned it with DeoxIT. now it works, around 90%..
sometimes i have to tap on it. well that's better than not working at all. lol
i wired up 2 x 3watts luxeon LED's i had laying around. took a piece of aluminum
angle polished it up and mounted the resistor and LED's to it.
i'll try to get a pic if yall want to check it out.
Y
yukisho
Banned
Apr 4, 2009
44
Saint George, Utah
May 31, 2009
#11
  • May 31, 2009
  • #11
Yeah get some pictures up. Planning on doing this next weekend.
toyman
1,944
54
79
Vernon BC
May 31, 2009
#12
  • May 31, 2009
  • #12
That's it.
Adam706
25
Columbus, GA
Jun 1, 2009
#13
  • Jun 1, 2009
  • #13
here some cell phone pics
toyman
1,944
54
79
Vernon BC
Jun 1, 2009
#14
  • Jun 1, 2009
  • #14
WOW, that's quite different than mine.
Apologize forthe fuzziness.
Adam706
25
Columbus, GA
Jun 1, 2009
#15
  • Jun 1, 2009
  • #15
oh lol.. i got my tilt switch fixed up.. i was posting pics of the LED's i mounted in the trunk for my cargo/luggage light.
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
All power lost at crank
  • saf_blu302
  • Mar 7, 2026
1994 - 1995 Specific Tech Mar 12, 2026
General karthief
70 Mach 1 Turn Signal Indicator light issue,
  • 70 Mach
  • Oct 19, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
Mach1 Driver
M
Electrical Fuse 8, Light Green / Black Wire
  • bleedinggreen
  • Jun 23, 2025
Fox 5.0 Mustang Tech Jun 26, 2025
bleedinggreen
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
