Just got done replacing the plugs. I had read that you had to shut the fuel off to the rails, run the engine until it stalled, unbolt the rails & pry them back, blah blah blah... None of that was necessary. In fact, it was as easy as changing them in my old 5.0. I guess I was intimidated by the coil packs...
Anyways, it was freakin' easy to do. I'm going to attempt to change the fuel filter tomorrow, as well as swap the stock H for a new Bassani catted X. Any pointers/hints for either? I should mention that the stock H is pretty rusty, so I soaked all of the bolts with PB Blaster.
I think there's a section at the beginning the advises the technician to use discretion and common sense when following the procedures in the manual.. to me, comon sense would say removing or disconnecting the fuel rails seems a bit much to change spark plugs.
