HERE WE GO:
Cleaning the Throttle Body isnt hard at all. Just remove the tubing the enter the throttle body, and spray some CARBERATOR CLEANER in it, I used 1/2 can before..get a smally tooth brush, and clean the circled plate(butterfly), and the opening where the plate rests...more than likely there is a huge build up there, and aswell clean with carb clean and brush where the plate pivots.(MAKE SURE NONE SPILLS OUT ON HEADERS, ITS OKAY FOR THE DIRTY FLUID TO GO INTO THE INTAKE) Replace all tubing and turn on the Car.It may take a while to turn on, It should Idle For Crap, for approx. 2 minutes. Dont REV the motor! Let it burn all the stuff by itself..then take it for a drive, you should notice a different in throttle response. Hope this helps.
