Turbo Kits
  • Thread starter Thread starter FrankenStang88
  • Start date Start date Feb 16, 2016
1 of 2 Next Last
FrankenStang88
21
Arizona
Feb 16, 2016
  • Feb 16, 2016
So i was looking on Late Model Restoration and they have two turbo kits i was interested in. One was a Helion kit for 4k and the other was an On 3 kit for only 1.5k. I read the descriptions and they both seemed to have the same parts included, except the fact that the cheaper kit has a bigger turbo. I dont know if im missing anything but which would be a better deal?
L
Lscam580
119
18
28
Grand Rapids Mi
Feb 16, 2016
  • Feb 16, 2016
The Helion kit is a direct bolt on setup no cutting or fab work. No headers are included so tack on another $500 (Yeah right ever tried doing a turbo setup? There is always something that needs fabed)
The on 3 kit needs intense fab work. Just because the turbo is bigger doesn't always mean it's better.
Reactions: Davedacarpainter
Jason 302
685
71
68
Newark, Ohio
Feb 17, 2016
  • Feb 17, 2016
Where did you read the Hellion kit doesn't have headers? Says it does in the parts list......
http://www.hellionpowersystems.com/index.php?option=com_content&view=article&id=131
To the OP, you get what you pay for. The standard turbo in the ON3 kit is made in Brazil or something like that. I've heard if you go that route, you should opt for the better turbo upgrade.
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Feb 17, 2016
  • Feb 17, 2016
I can't for the life of me understand why people bother with turbo kits on stock, block Fox bodies?
They're twice the price of a tried and true centrifugal supercharger (Paxton, Vortech, ATI....pick one). Three times as complex, far more involved to install, NEVER a direct bolt on, always perform inconsistently and can be a real pain in the ass to tune.
Any of the above mentioned blower companies produce kits more than capable of producing power levels that far exceed the strength of the stock block. The fact that they also all now build self contained kits that require no additional oil lines to plumb makes them even more attractive.
.....yet guys still allow themselves to be brainwashed into thinking that "turbo" is the only way to go.
Reactions: 84Ttop, Farrell5.0, A5literMan and 2 others
2000xp8
SN Certified Technician
Aug 8, 2003
8,063
1,647
194
NJ
Feb 17, 2016
  • Feb 17, 2016
Any of the above mentioned blower companies produce kits more than capable of producing power levels that far exceed the strength of the stock block. The fact that they also all now build self contained kits that require no additional oil lines to plum makes them even more attractive.
I used to say the same thing. I still think it, but mostly keep it to myself these days.
Many do it and say they wanted to be different. I sorta get that, but it's been done enough times now that it really doesn't get any more street cred than an SC.
Vortech's are affordable and predictable, turbo's, who the hell knows how much trouble it will be. Some none, some so bad that you might as well toss it in the garbage.
Not to mention when a part on a turbo setup fails some companies choose to blame the installer.
If you gave me an On3 kit for free, i'd either sell it and buy an S trim or trade it for one.
Hellion kits are pretty nice, but double the cost of a good sc? That makes it less attractive.
I think turbos have a place, just not on a street car that will make say 600rwhp or less. You gotta at least be after more hp than a T trim IMO.
Reactions: Davedacarpainter, A5literMan and mikestang63
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Feb 17, 2016
  • Feb 17, 2016
Do the turbo kits come with a free set of jackstands? Get a Vortech
Reactions: TOOLOW91, Farrell5.0 and Bullitt347
90sickfox
Wasn't a pretty sight...and I've got big hands
Mar 2, 2015
6,950
5,826
213
Feb 17, 2016
  • Feb 17, 2016
Turbos are by no means an easy route. I know two guys that have been running on3 kits for a couple years....one has had no problems and self tunes with moates quarter horse....the other guy has been through a block and a ish load of other issues. The first guy is mild mannered and usually drives the speed limit...the other guy is a boasting ignoramous that loves to show off every chance he gets and who knows if his car has ever been properly tuned. Guy one is a nuclear engineer....guy two is a self proclaimed mechanic. I love the sound of a v8 with a blow off valve. The on3 kit doesn't come with fuel injectors, maf, wideband o2, or tune. Also, the ceramic ball bearing turbo is way better than the journal bearing turbo in the kit. You have to expect to spend a couple grand more with either choice. The trans or clutch, brakes, suspension, and the chassis have to be able to handle the power either way. A turbo is in my future but I'm almost 40 and a master mechanic that can tune and install my own parts....a dart block is also in my future....when I hit the lotto or go to heaven. [emoji12]
chriscash
50
  • Feb 18, 2016
I'm running a single gt45 on my 347 dart (first had it on a stock block which didn't last long on 12psi) and love it. Yes was a complete pain to install but the outcome is definitely worth it. Crazy power and hard to beat the sound of a turbo v8. Also found the megasquirt pnp ecu to be very user friendly and easy to tune with the turbo system.
Boosted92LX
5,721
4,244
224
Feb 19, 2016
  • Feb 19, 2016
I don't know why anyone would buy a turbo setup for a fox. Stupid...
Reactions: krazedstang, TOOLOW91, 84Ttop and 3 others
chriscash
50
#10
  • Feb 19, 2016
  • #10
To piss guys like you off loll
CarMichael Angelo
8,909
234
Birmingham, al
Feb 19, 2016
#11
  • Feb 19, 2016
  • #11
chriscash said:
To **** guys like you off loll
You think you might wanna check into why this guy's screen name is " boosted 92lx" before you decide he falls under the "guys like you" category there chief?
Reactions: 1990Coupe, Davedacarpainter, A5literMan and 2 others
chriscash
50
#12
  • Feb 19, 2016
  • #12
It was a joke hence the "lol"
hoopty5.0
mechanicus terribilis
7,822
6,975
214
SW Houston
Feb 19, 2016
#13
  • Feb 19, 2016
  • #13
OHhhhh man.
Reactions: Boosted92LX
Boosted92LX
5,721
4,244
224
Feb 19, 2016
#14
  • Feb 19, 2016
  • #14
hoopty5.0 said:
OHhhhh man.
Well, at least the car makes up for it by being slow..
Reactions: Davedacarpainter and Bullitt347
MY 85 GT
1,852
208
104
New Jersey
Feb 19, 2016
#15
  • Feb 19, 2016
  • #15
I went turbo crazy power very fast.... but next build will be a supercharger...
Boosted92LX
5,721
4,244
224
Feb 19, 2016
#16
  • Feb 19, 2016
  • #16
I'll say it's not for the impatient. What made me want to do it was the fact that comparable sized turbo to sc compressor wheels head to head... The turbo will typically net 100 lb ft more torque. And mine does... But don't ask how many swear words it took to get it. All worth it kicking hell out of people on the freeway, though. It pulls like mad up to the rev limiter in every gear.
Reactions: Davedacarpainter and MY 85 GT
mikestang63
Aug 27, 2012
11,606
8,859
214
In the garage
Feb 19, 2016
#17
  • Feb 19, 2016
  • #17
Reactions: Davedacarpainter, A5literMan and Boosted92LX
Boosted92LX
5,721
4,244
224
Feb 19, 2016
#18
  • Feb 19, 2016
  • #18
mikestang63 said:
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Feb 19, 2016
#19
  • Feb 19, 2016
  • #19
mikestang63 said:
I would find it interesting how many people will get that. Lol. I'm feeling old.
chriscash
50
#20
  • Feb 19, 2016
  • #20
Simple mistake of a joke in the morning before coffee yall gotta know how that is. No where near awake.
1 of 2 Next Last
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 4, 2026
JD1964
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
"Tuning" Vortech kit with FMU discs- question
  • nicholase
  • Jun 22, 2024
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 13, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Monday at 2:12 PM
mattcrp1
M
