Turbo Question
  • Thread starter Thread starter foxmustangman
  • Start date Start date Feb 20, 2009
foxmustangman
196
Idaho
Feb 20, 2009
  • Feb 20, 2009
If anyone here knows about turbos I'm loooking to do a custom set-up on my car. I found a used Garrett T-25 turbo for sale. Are these any good? I'm looking for a high-end power turbo. Thanks.
T
t4lude98
14
  • Feb 20, 2009
im new to v8s but a t25 seems very small it would spool too fast for what you want
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Feb 20, 2009
  • Feb 20, 2009
you damn sure wont be using it as a single. its maxed as a twin setup in a stock car.
F
fastfiftymike
47
  • Feb 20, 2009
If your looking for a High end power turbo, look into the T6 series.
Mike
BK_CAULEY
Dec 26, 2006
49
Thomasville, ga
Feb 20, 2009
  • Feb 20, 2009
www.turbomustangs.com /thread
Saleen8786
209
Marlton, NJ
Feb 20, 2009
  • Feb 20, 2009
if anything just grab the turbo's off of the svo's or 83-86 turbo coupes. They were t3's and you could do a cheap twin turbo build.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Feb 20, 2009
  • Feb 20, 2009
No, don't grab the turbos off of SVOs. It's hard enough to find them for SVOs without having to compete with junkyard turbo scavengers. That said, two .60/.63 Garrett T3s will easily make enough power to split a stock 5.0 block. A single T70 will be capable of the same.
Forget you ever heard of the T25. It is too small for what you want, even as twins.
M
mkhalil83
79
  • Feb 20, 2009
Does it matter when it comes to brandnames?
parrish5o
Dirty South
Feb 20, 2009
  • Feb 20, 2009
I've got to agree, the 25s are tiny and would not be worth the install.
foxmustangman
196
Idaho
Feb 21, 2009
#10
  • Feb 21, 2009
  • #10
So does the 25 and 60 or 70 referr to to turbo size? A guy is selling his turbos from his srt-4 neon. Would they do me any good?
foxmustangman
196
Idaho
Feb 21, 2009
#11
  • Feb 21, 2009
  • #11
And what should I look for when buying a used turbo? What should I check to make sure everything works?
66sprint6
131
Feb 21, 2009
#12
  • Feb 21, 2009
  • #12
DONT buy that crap off an SRT4...think about it, thats a 4 banger car and your wantin to boost a 5.0. For what its worth, im runnin a stock Buick GN turbo on my 200ci inline six and its a little small for what I wanna do.
If you do go huntin used, check to see that the impellar spins free and wiggle it back and forth, side to side to see if there is any shaft-play. There should be little to none. Check out turbomustangs for sure, TONS of awesome stuff.
Good luck!
Matt
65ShelbyClone
4,675
38
119
Feb 21, 2009
#13
  • Feb 21, 2009
  • #13
foxmustangman said:
1.) So does the 25 and 60 or 70 referr to to turbo size?
2.) A guy is selling his turbos from his srt-4 neon. Would they do me any good?
3.) And what should I look for when buying a used turbo? What should I check to make sure everything works?
1.) Typically, but there are exceptions.
2.) The turbine housing and Dodge exhaust manifold are all one piece, so no.
3.) About the only thing you can do is feel for excessive shaft play. All non-ball bearing turbos have some radial play, but axial play should not be noticeable.
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Feb 21, 2009
#14
  • Feb 21, 2009
  • #14
just buy a Master power t-70. you can get them for like 500-550 brand new from alot of vendors on theturboforums.com. they are proven turbos and will be able to split the stock block without breaking a sweat.
foxmustangman
196
Idaho
Feb 22, 2009
#15
  • Feb 22, 2009
  • #15
I'd like to keep my block in one piece thanks. lol
Okay, I'll look for a T70 or similar. Thanks all.
blackened88lx
Connecticut
Feb 22, 2009
#16
  • Feb 22, 2009
  • #16
Red198 said:
The Turbo Forums.com /thread
What he said.
foxmustangman
196
Idaho
Feb 22, 2009
#17
  • Feb 22, 2009
  • #17
Yeah, I went there first to try and find some things out.
blackened88lx
Connecticut
Feb 23, 2009
#18
  • Feb 23, 2009
  • #18
I hear a lot of good things about the MP T70. It had some troubles in the beginning but sounds like everything has been fixed, and it sounds like the best bang for your buck when doing a mild rustang build. If you want a little more serious turbo I might have a really nice unit for sale along with a turbo kit.
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
E
Serpentine ac bracket differences
  • EspaceF1Fan
  • Apr 1, 2026
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Apr 1, 2026
OX1
O
G
Engine ECU Question
  • GeorgeE
  • Oct 12, 2026
Fox 5.0 Mustang Tech Oct 19, 2026
JD1964
Engine Are These rings OK?
  • PonyGTrider
  • Sep 21, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
PonyGTrider
