I was reading up a little on the wiring changes for a 87lx to 87-88tc(la3) install, i pretty much understand the vam deal (or alteast im comufzuled enough to think i understand
) on 140cilx site he said the 87-90lx's already have a ACT sensor, so when i do the swap should u just use my n/a'd intake with the sensors in it (i currently have a 86tc motor, no act sensor) or is there a differnce in pinning or senor types...just a little mixed up on that aspect of the swap. Also with the preimum wiring jumping, if you are using a gillisboost controller do u need to even mess with that wiring? (i.e. does it affect more than computer controlled boost settings, like timing or fuel curves?)
thanks alot guys, ill try better to understand all these sensors and wire stuff
keep it real
-wood
) on 140cilx site he said the 87-90lx's already have a ACT sensor, so when i do the swap should u just use my n/a'd intake with the sensors in it (i currently have a 86tc motor, no act sensor) or is there a differnce in pinning or senor types...just a little mixed up on that aspect of the swap. Also with the preimum wiring jumping, if you are using a gillisboost controller do u need to even mess with that wiring? (i.e. does it affect more than computer controlled boost settings, like timing or fuel curves?)thanks alot guys, ill try better to understand all these sensors and wire stuff
keep it real
-wood
