chickendreamer
gcomfx.com said:May not be recommended, but it's worked for 5+ years and a LOT of juice ran through it for 2 of those years. Ran 2 bottles a w/e for longer than I care to admit (threw away a lot of money).
My stock rev limiter is way too low to get the full potential out of my car. As a matter of fact I don't think I could spray the car with the juice on. I'll hit the limiter in each gear which is MUCH more dangerous.
The car doesn't detonate with the timing dropped down as long as the plug gap is closer and the fuel pressure is up.
As far as building a new engine... that's been the plan all along anyway. The stock engine is close to 200,000 miles and I've never had the valve covers off.
I need to figure out the idling issue as putting a new engine in will most likely have the same results. I would rather find the problem BEFORE I have to swap engines.
yeah I guess if you've been running it for that long it's ok to keep the chip in. Not much it could do now...
But yes, swap the maf/injectors and see how that affects your idle.
btw, i switched my signature just for you.
I noticed the sig change.... I signed up on turbostangs just to see your pics. My username there is 100mphclub.com. Nice thread/write up.
