turn signal on pass. side fast flash???
Bosko5.0
1,067
longwood, FL
My turn signal on for the pass. side flash real fast but the other side is normal.:shrug: All four turn lights are working:shrug: :shrug: :shrug: .
If it helps I had the passenger tail light off too paint it.:shrug:
WHY? WHY? WHY?
Usually a bad bulb. Even if the filament is working, if the bulb is on its way out, or the filament was damaged without breaking (stretched out), they have less resistance and will cause the lights to flash faster. Also, moved to tech.
I'd also just go over your recent work. Wiggle the harness and ensure your ground is solid.
Good luck.
