turn signal problems.....
  • Thread starter Thread starter 88hatchblack
  • Start date Start date Apr 28, 2005
88hatchblack
163
Willard, Ohio
Apr 28, 2005
  • Apr 28, 2005
i can't seem to make my turn signals work. all fuses, bulbs, and grounds are good. when i turn on the lights, both turnsignals light up, but don't flash. without the lights the right turn signal comes on, but won't flash. any suggestions
slow88LX
25
  • Apr 28, 2005
i just fixed mine. my turn signals would not work unless i giggled the key into a "special" spot. also my a/c blower motor did not work.
solution: the ignition contact switch
i got a new one from ford...$8 part!!!
here is a link to pics of the piece that was broke on my car:
link to pics of the ignition pieces
N
ninty1gt
20
san antonio, tx
Apr 28, 2005
  • Apr 28, 2005
check the flasher behind the glovebox
Zero_chance
1,244
Maricopa, AZ
Apr 28, 2005
  • Apr 28, 2005
Id start with the flasher first, like 91 said. Always better to start with the easy stuff.
I_AM_CANADIAN
189
B.C.
Apr 28, 2005
  • Apr 28, 2005
It could also be behind the center part of the dash (behind stereo etc.) as well. Ford kinda threw them all over the place in these cars. Good luck with it.
HISSIN50
34
129
Apr 28, 2005
  • Apr 28, 2005
famous last words.
sgarlic
3,085
Apr 28, 2005
  • Apr 28, 2005
Don't even get me started on the turn signals not working. Jesus.
Check the blinker knob assembly itself, the blinker relay, the hazard relay, the hazard switch assembly, and if none of that fixes is, just be like me and use your hands
88hatchblack
163
Willard, Ohio
Apr 28, 2005
  • Apr 28, 2005
what does this flasher look like? i have never noticed it in all the times i've had the car apart.
T
tomabram
Banned
Apr 1, 2005
66
  • Apr 28, 2005
The flasher is NOT behine the glovebox or behind the stereo in 88.
Remove the small panel directly under the steering column. After the panel is removed look to the left about an inch or two in. The flasher is right there.
88GTtom
198
Woodbridge NJ
Apr 28, 2005
#10
  • Apr 28, 2005
  • #10
correct, remove like he said, takes a minute. mine was fastened to something so it wouldent move. cant remember what it looked like, but it should stand out. i would go buy one, they cant be more then 10 dollars. then look for the old one, or just go ahead and look for it... borrow a friends to see if it is the problem.
T
tomabram
Banned
Apr 1, 2005
66
#11
  • Apr 28, 2005
  • #11
The stock one dosent really look like the aftermarket one. The stock one is round and light green. New ones are usually Silver. Paid $2.29 for it.
88hatchblack
163
Willard, Ohio
Apr 29, 2005
#12
  • Apr 29, 2005
  • #12
thanks guys! fixed the problem
HISSIN50
34
129
Apr 29, 2005
#13
  • Apr 29, 2005
  • #13
what was the solution?
slo65
448
Southern California
Apr 29, 2005
#14
  • Apr 29, 2005
  • #14
SOLUTION! i bought my 5.0 over a year ago, i havent ever had turn signals but the hazards work
Electrical Turn Signal / Lights Issue
  • 86SilverFox
  • Jun 2, 2025
Fox 5.0 Mustang Tech Jun 3, 2025
General karthief
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 5:36 PM
AeroCoupe
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
