i can't seem to make my turn signals work. all fuses, bulbs, and grounds are good. when i turn on the lights, both turnsignals light up, but don't flash. without the lights the right turn signal comes on, but won't flash. any suggestions
ninty1gt said:check the flasher behind the glovebox
famous last words.Zero_chance said:Id start with the flasher first, like 91 said. Always better to start with the easy stuff.
I_AM_CANADIAN said:It could also be behind the center part of the dash (behind stereo etc.) as well. Ford kinda threw them all over the place in these cars. Good luck with it.
tomabram said:The flasher is NOT behine the glovebox or behind the stereo in 88.
Remove the small panel directly under the steering column. After the panel is removed look to the left about an inch or two in. The flasher is right there.
88hatchblack said:thanks guys! fixed the problem
but the hazards work
