Turn Signals dead
  • Thread starter Thread starter farmboy89
  • Start date Start date Apr 11, 2008
F
farmboy89
38
  • Apr 11, 2008
The turn signals in my 66 just went out a week ago and i can not figure out what the problem is. I checked all the fuses, and the lights. What else can be the problem. I checked the books about it, and no trouble shooting has helped. The signals just went out without any warning, no slow blink, no one side blinking not the other, inside and outside don't blink, I cannot figure out what it is. I know that someone will know right away what it is, but I have no clue.
Thanks
Ben
JDS68Stang
153
New York State
Apr 11, 2008
  • Apr 11, 2008
Try replacing this first:
Its right under dash near steering column.
Then start checking ground connections (trunk ones are easily accessable)
Good luck, I have similar problems.
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Apr 12, 2008
  • Apr 12, 2008
Check the voltage comming out of the turn signal switch in the steering column. If you get voltage there, then it provably is the blinker.
F
farmboy89
38
  • Apr 12, 2008
I forgot to say that i did replace that. I still need to check the connection there. If the connection is dead what else can it be?
D
danny clemens
728
  • Apr 12, 2008
I've saw bad grounds mess with turn signals but I've never saw it get both sides at once.
STSFCTN67
450
Denver, CO
Apr 12, 2008
  • Apr 12, 2008
Double check the fuse box again with the ignition on. Run a test light both sides of the fuse. All should light up. Trace the wires with a wiring diagram. Has anything else gone out or have been unplugged? Check all of your connections at the lights. Do your hazards work? Even though these are compltely seperate it might help to look.
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Z
Turn signals not working at all, but hazards do. 91 fox LX 5.0
  • Zeke1995
  • Jun 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
Jarhead67
J
