turn signals / defrost / hardarzd lights issue
fox-gt
204
TN
I'm have a wierd issue with my 93 GT. The turn signals, defrost and hazard lights will not work when I first start the car. The head lights, AC blower, bright headlight indicator work fine. No issues starting either.
After driving the car for about 10 or 15 minutes they will start working. It seems like it is taking longer and longer for them to come on.
Thanks
I found a few things here also that might help:
http://forums.stangnet.com/752749-turn-signal-help-90-gt.html
There was a recall on your Ignition switch.
If it hasnt been done before, and they CAN still do it, that would be free.
I dont think thats it.
First, of course, check the fuses.
second, the defrost and hazard are on the same switch, a loose wire there could do it.
The turn signals, could be as easy as a relay going bad.
Both when warm, start working better. Have heard of that before many times.
Without going over the wireing diagrams, i cant say for sure if there is anything wire wise, that they woulld have in common.
Try checking the ignition switch. The plastic part becomes loose where it attaches to the metal switch and causes the blinkers, hazard lights, and defroster to not work.
