turn signals
  • Thread starter Thread starter rowdiestang
  • Start date Start date Sep 29, 2009
R
rowdiestang
  • Sep 29, 2009
I know that there are a lot of threads on this subject. I think I have read all of them. My question is are the both flashers interchangeable? Can I check if I have a bad flasher by removing the turn signal flasher and swap it with the hazard flasher? My hazards work fine but not my turn signals. I took the flasher out of the turn signals (behind the radio) and put it where my hazard flasher goes and my hazards did not work, so I took the hazard flasher and put it on my turn signals but the turn signals did not work either. I have checked the fuse, ignition switch, and mfs and everything looks good. This has been a year long problem and I am ready to get it fixed yesterday!
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 29, 2009
  • Sep 29, 2009
The hazard flashes 4 bulbs at once, the turn signal only 2 at once. I would guess that you could test a turn signal flasher in place of a hazard, but not the other way around.
The flasher is a self resetting circuit breaker. The current draw from the bulbs heats a spring strip. When the strip gets hot enough, it pops away from the contact and opens the circuit. The open circuit deprives the bulbs of power and they go out. The spring strip cools down and resets against the contact. This turns the bulbs back on until the spring strip gets hot and trips again. In theory, more current makes it flash faster.
R
rowdiestang
  • Oct 4, 2009
I changed the flasher and it didn't work. I did put in a tilt steering column out of a 88 5.0 a while back but I believed the flashers worked after I did that. I only drive my mustang about 2000 miles a year if that and I dont remember. All the wires connections are good going to the hazard switch and the MFS. The fuse is fine I have my electric fan wired to that fuse also and its been like that for 10 years. My blower works fine for the heater but could it still be my ignition switch. I'm a decent backyard mechanic but I dont have a clue about electrical
Repostyle
538
Portland, OR
Oct 4, 2009
  • Oct 4, 2009
Do you hear the click of the relay when you turn your turn signals on? If not then you have two options, either the multi function switch (Turn signal lever) has gone bad, or the relay, swaping the relays might work, but the signal may stay lit without flashing because of the lack of current, but they would work. The hazards would also flash but might be very fast and hard to see with the turn relay. If, you get hazzards but no signals by swapping relays then it's most likely the switch, I had the same issue, a new switch and cured it for me.
R
rowdiestang
  • Oct 5, 2009
I will try putting a new MFS on and will get back to you. Thanks for all the help!
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
Fox Turn signal flasher keeps failing
  • keel
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2026
Electrical Foxbody Dash & Hazard lights not working
  • sjmcr
  • Jun 30, 2025
Fox 5.0 Mustang Tech Jul 27, 2025
Mindseye007
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
Electrical Turn Signal / Lights Issue
  • 86SilverFox
  • Jun 2, 2025
Fox 5.0 Mustang Tech Jun 3, 2025
General karthief
