  • 1994 - 1995 Specific Tech
tweecer + fpr?
  • Thread starter Thread starter Mustangless
  • Start date Start date Jul 19, 2006
Mustangless
903
home
Jul 19, 2006
  • Jul 19, 2006
Is a adjustable fuel pressure regulator needed if you have a tweecer? This will be for a turbo mustang with 255 hp fuel pump, 42lb injectors, with calibrated maf.
Can you do whatever is needed with tweecer, or is a fpr still needed?
vristang
4,933
101
124
Seattle
Jul 19, 2006
  • Jul 19, 2006
I asked this a while back and the answer seemed to be that the stock regulator should be ok, as long as you don't have issues with the pump over loading the regulator.
It is rumored that the stock regulator can have trouble with the larger pumps.
I switched back to the stock regulator, and didn't seem to have any troubles.
All of the fuel adjustments made in the EEC assume stock fuel pressure (38-40 psi depending on who you ask).
jason
blksn955.o
3,263
st.louis mo 314
Jul 19, 2006
  • Jul 19, 2006
no real need.
I am not a boost guy as far as my combo but doesnt' the boost hook up to the reg. and raise the fp anyway on those combos?
I know most dry n2o kits also hook up to the reg. with a T and raise the FP but since they are at WOT it shouldnt sque the data too much as far as adaptive and logs.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jul 19, 2006
  • Jul 19, 2006
Save Your $$$
None Needed
Better Yet ... Put that money towards a WB
Grady
69clark
731
Ravena, NY
Jul 20, 2006
  • Jul 20, 2006
R
rockin_rick
968
Jul 20, 2006
  • Jul 20, 2006
I ran a tweecer and had a kirban AFPR and switched back to stock....
The only benefit would be if your injectors are slightly undersized. But even then, I'd suggest running the stock AFPR and using the right injectors.
Rick
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
I
1994 Cobra - Fuel Pressure Drops Revving at Idle
  • IconicSilverGT500
  • Apr 11, 2026
1994 - 1995 Specific Tech Apr 24, 2026
Mcmahst
L
2003 mustang v6 3.8 fuel issue
  • lacole1
  • Jul 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 26, 2026
apple99Mustangdude
A
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
