  • 1994 - 1995 Specific Tech
twEECer installed, but problems
  • Thread starter Thread starter CManT1914
  • Start date Start date Aug 25, 2005
1 of 2 Next Last
CManT1914
3,172
Killeen, Texas
Aug 25, 2005
  • Aug 25, 2005
Got the twEECer installed, but when I went to start up the stang, it wouldn't run at all. It died as soon as I started it, and the only way to keep it running was to hit the gas. Check engine light was on as well. Any ideas?
Oh yea, I tried clicking read read tweecer and it said comm fail. With the car off, it reads it fine.
CManT1914
3,172
Killeen, Texas
Aug 25, 2005
  • Aug 25, 2005
Woa, I clicked read EEC, and it came up with some BIZARRE values. Like a 14,000 idle speed, 64 O2 sensors, 28lb injectors, and with the maf curve, every point is 4.0156v, reading 5170hg/hr air, lol. WTF??
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Aug 25, 2005
  • Aug 25, 2005
You have to have the Tweecer on position 5 (all the way to the right) That will keep the computer at its stock stock settings.
Let us know.
RC
CManT1914
3,172
Killeen, Texas
Aug 25, 2005
  • Aug 25, 2005
Let us know.
RC
Nope, it's in position 1, and it ran okay before the twEECer, not it won't run at all.
M
mackey
1,284
Beverly, Massachusetts
Aug 25, 2005
  • Aug 25, 2005
Before you run the car again load the default settings you can get the default cobra tune from the tweecer website. Hit write to tweecer on position 1. Then start the car and it should run right.
94GTLaserRC
11,178
Aug 25, 2005
  • Aug 25, 2005
did you try it in position 5?
CManT1914
3,172
Killeen, Texas
Aug 25, 2005
  • Aug 25, 2005
I didn't try it in position 5.
When I pulled the PCM back out, the tweecer was only half on. This was probably caused by pulling the PCM out, but I did notice a lot of crap on the circuit board where the tweecer connects again. I'm gonna try cleaning it again and go from there.
Then I might use the Cobra tune until I get it running then change some stuff around.
Zero Signal
2,633
Tucson, AZ
Aug 25, 2005
  • Aug 25, 2005
Like I said in the other post, select CBAZA strategy on the bottom before you do anything.
94GTLaserRC
11,178
Aug 27, 2005
  • Aug 27, 2005
I put a wedge in there to keep it from moving around....then duct taped in it place
RC
95_cobra123
213
Lovington, IL
Aug 27, 2005
#10
  • Aug 27, 2005
  • #10
Call me a newb or w.e but wth is a tweccer or whatever it is called and what all does it do and where can i get one??? LOL thanks
88GT460
338
Arkansas
Aug 27, 2005
#11
  • Aug 27, 2005
  • #11
what is tweecer, what does it run on.. is it a handheld thing ? where can I get it ?
88GT460
338
Arkansas
Aug 27, 2005
#12
  • Aug 27, 2005
  • #12
holy crap.. i just posted the same thing.. hahaha
CManT1914
3,172
Killeen, Texas
Aug 27, 2005
#13
  • Aug 27, 2005
  • #13
www.tweecer.com
It's an EEC tuner that plugs into the J3 port on your EEC. Then a usb cable runs from that to your desktop/laptop and it has software that allows you to reprogram the entire EEC. You can change stuff like fuel tables, spark tables, idle speeds, maf curves, injector slopes, fan temps, turn off egr, turn off smog, all kinds of stuff.
$380 plus shipping for a new base model
$550 plus shipping for a new RT model. (RT allows you to datalog information as you drive around)
D
DavidNC
119
#14
  • Aug 27, 2005
  • #14
Make sure your j3 port contacts are clean of the clear protective coating. You can lightly pull a razor blade accross the contacts to scape it off, but leave the solder in place. You can't run in position 1 unless you've loaded a tune. Download your car's stock tune while in position 5. Save it to position 1 and run. then run from pos1. When this works for you, you are ready to start tuning.
95_cobra123
213
Lovington, IL
Aug 27, 2005
#15
  • Aug 27, 2005
  • #15
what type of hp can u pic up from getting one with the mods i have???
D
DavidNC
119
#16
  • Aug 27, 2005
  • #16
BTW; we sell the TwEECer RT to Stangnet members for $540 shipped.
A new 94-95 data file has been released, and it has an additional 60-65 parameters. A lot of the aode pararmters have been added.
You can request the new dat file from who you purchased your TwEECer from.
CManT1914
3,172
Killeen, Texas
Aug 27, 2005
#17
  • Aug 27, 2005
  • #17
What if I bought my tweecer used from a guy? Where can I get the .dat file?
dstanggt50
1,316
Woodinville, WA
Aug 27, 2005
#18
  • Aug 27, 2005
  • #18
don't they have a file for 94-95 gt's, or are all of you tweecer users running a cobra tune ???
CManT1914
3,172
Killeen, Texas
Aug 27, 2005
#19
  • Aug 27, 2005
  • #19
Yea, but this is a new strategy. I just downloaded it and it has a lot of new scalars in it as opposed to the old CBAZA strategy.
G
Green 94 5.0
2,601
12
79
Ft. Lauderdale, FL
Aug 28, 2005
#20
  • Aug 28, 2005
  • #20
your car is not running because you have a tweaked bin file loaded for whatever combo the previous owner had. head over to the tweecer website and download either the t4m0 or j4j1 bin. if you choose the j4j1 and dont have 24's, you will need to change the injextor slopes. write either one to the tweecer and the car should run fine. as far as securing the tweecer to the j3 port, i used a couple pieces of electric tape. i had no rpoblems after that.
1 of 2 Next Last
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
Distributor installed wrong
  • djj62478
  • Jun 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
T
Help with a 95 5L crank no start
  • TheBubbaJoe
  • Nov 4, 2025
1994 - 1995 Specific Tech Nov 5, 2025
AeroCoupe
