Hey guys, I just got a used tweecer installed today. Everything was going relatively smoothly.
I am just starting so I was just doing basic stuff l like figuring out how to read my eec and save it and write it to a switch. I was able to write the stock file to a switch and run the car, however the data logging was not collecting data, Does the tweecer have to have the data log info written to it for data log to work properly? the time would run but no response for the dash board.
Now my real problem,
My issue is: I am not sure if i accidentally wrote a wrong calibration to a switch because when I move it to that switch the fuel pump constantly runs??! To fix this I thought I would just write the stock file to this switch (while the fuel pump was running) this caused cal edit to begin writing but crashed and gave a message about "null" something.
After this the fuel pump turned on seemed to be much louder too so I the switch to by pass the tweecer and get back to square one. When I attempted to start the car, it barely turned over and started clicking like a bad ground or low battery.
I should also mention that when the car was running before the tweecer, the voltage has sort of been oscillating a little. Like a possible bad ground.
Well guys sorry for the long post.
I would like some input from you guys, is there a way to erase everything written on the tweecer?
My tentative plans: Put the battery on a charger, clean grounds, reinstall software, hopefully format the tweecer? The thing I dont get is why the car has been starting fine and now started that funky starter kind of bad ground clicking right after that crap happend with the fuel pump.
Thanks guys!:SNSign:
So to fix it I
So to fix it I
