Tweecer...........
  • Thread starter Thread starter Cwalk
  • Start date Start date Mar 24, 2007
Cwalk
78
Virginia Beach, Va
Mar 24, 2007
  • Mar 24, 2007
Does a tweecer plug into the back of the A9P? And it allows you to adjust timing etc.,? Does it allow you to reprogram the ECU for bigger injectors? What's the difference between the tweecer and the R/T?
1991vert
1,103
Ludlow, MA
Mar 24, 2007
  • Mar 24, 2007
R/T can datalog
HISSIN50
34
129
Mar 24, 2007
  • Mar 24, 2007
The tuning sub-forum and various tuning forums have some nice basic info.
You can change nearly any parameter in the computer with the twEECer.
The RT gives the ability to datalog, which is worth every penney if you're into this stuff.
You'd likely want a WB and cheap laptop.
Good luck.
ninety15.0
1,336
  • Mar 24, 2007
yes the tweecer is a piggy back system that allows you to adjust almost all of the parameters in the computer....injector size can easily be adjusted. The R/T version stands for real time. it can be used to data log the cars performance by keeping track of up to 14 input/sensor values so you can look back at them and analyze the effects of your changes. get one....they're cool
Cwalk
78
Virginia Beach, Va
Mar 24, 2007
  • Mar 24, 2007
thanks for the info. they seem like a cheap way for us to tune fox's. like the guy's with SCT tuners.
gaslight
3,365
Maine
Mar 24, 2007
  • Mar 24, 2007
not the easiest to learn though. Do lots of research online before you mess with anything. There are a lot of things you can change and therefore screw up if you aren't careful.
1991vert
1,103
Ludlow, MA
Mar 24, 2007
  • Mar 24, 2007
that's why im scared of the twEECer lol
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
May 2, 2007
  • May 2, 2007
the tweecer manual has a chart with some good starting numbers for different injector sizes
http://www.v8mustang.com/Getting-Started.pdf
page 15
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Electrical 92 Fox 5.0 no start
  • xwhiskeyechox
  • Apr 24, 2025
Fox 5.0 Mustang Tech Apr 25, 2025
AeroCoupe
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
