If you have read any of my threads I have had trouble with a low trap speed....well I am very happy that I raised them up......and beat my best twice...with a somewhat weak 60' foot. I ran 4 times 3 different ways .....I am either hitting the rev limiter........or trans is slipping.....or a third un-explainable hestitation in shifting up......and saw a Top Fuel crash.....thank God the driver was not hurt........but here are the following runs with what I did..
1st Run......regular Chip setting.....left the car in drive and let it shift on it's own.....car hesitated between 2/3 gear then took off
1.976
5.668
1/8-8.741 @80.32
1000-11.391
[email protected]
2nd and third run I set the chip to advance timing and lock up convertor...both times I manually shifted and took it 6K on the stock tach..
2) best I've gotten..previous was 13.51?
1.910 60'
5.552
[email protected] 1/8
11.192 1000'
[email protected]
3rd
2.050 60'
5.729
8.741 @82.35 1/8
11.320 1000'
13.497 103.62
4th and final run......left the chip on advance timing and stall convertor lock up....let it shift itself.......this time no hesitation between shift...but a crappy 60' it was late and temps were cold...spun way too much....
2.152 60'
5.778
11.358 1000'
[email protected]
Cliff notes.....beat best ET....most important to me was that my traps are higher
and there may be a little left to possibly get the AODE to 12.99s.......so Grady will leave me alone......
got to find out what the hesitation was ....rev limiter, slipping trans, or another issue I'm not aware of.....lol
Will
1.976
5.668
1/8-8.741 @80.32
1000-11.391
[email protected]
1.910 60'
5.552
11.192 1000'
[email protected]
3rd
2.050 60'
5.729
8.741 @82.35 1/8
11.320 1000'
13.497 103.62
2.152 60'
5.778
11.358 1000'
[email protected]
got to find out what the hesitation was ....rev limiter, slipping trans, or another issue I'm not aware of.....lolWill
......Yes....the U/D's worked well......drove home at 11 pm lights on......didn't notice any probems with charging......
it was pretty fun
he launched off the trans break and it spun the slicks horrible at the line ....so it thought it wasnt prepped so he backed out of it and tried the other lane...when he pulled up to do his burnout he spun the tire on the rim
and when he decides to use the bottle it will get a 250 shot of it soo all hell will break loose then lol
