Uhmm.. broken o2 sensor
Blakthorn
299
US
crawled under the car to check things out and noticed my passenger side o2 sensor is plugged into my upr x pipe....but guess what...the other end is cut and not plugged into the car..i always skimmed over this because i just checked the x pipe to see if they are there
so for about 4 months i have been running the car with only 1 o2 sensor, i have an 87 so no check engine light and i was clueless
What happens when only 1 sensor is working, any negative affects to the car?
Open loop is the mode the EEC goes into during startup and when cold. The car runs on preset fuel tables and takes input from a very few number of sensors. A lot of things have to be "right" in order for the EEc to go into closed loop and vary spark and fuel tables to run as effiently as it can. Something as small as a bad ECT sensor or coolant temp sensor can cause the EEc to remain in open loop. What I don't know, is if having only one of two 02 sensors operating correctly will cuase that condition. If the motor is running strong and not killing you in gas then leave it. If you ever go to hook that sensor back up, it will likely need replacing. running that long wihtout a preheater in teh exhaust stream has surely ruined it by now.
