Underbody........
  • Thread starter Thread starter Car RamRod
  • Start date Start date May 26, 2005
Car RamRod
Banned
Mar 30, 2005
623
Queens, NYC
May 26, 2005
  • May 26, 2005
while im doing my 5 lug swap/exhaust work, what else should I be considering putting under my car? Its an 89 notch, 5speed puttin down about 260hp. Im sticking to the stock springs, but adding the white kyb shocks. Im gonna fab up some sfc's while um under there too. Is there anything else I should really put on while im at it? nothing unnecasaily expensive too.
thanks
Luvmy88
136
  • May 26, 2005
Changed your fuel filter lately?
stang22
1,318
Washington, D.C.
May 26, 2005
  • May 26, 2005
It would be a good time to remove the rear-end, paint it and throw some new bushings in if you haven't already. Particularly the upper control arm bushings that are attached to the rear-end.
Battle box reinforcements?
Tim
Car RamRod
Banned
Mar 30, 2005
623
Queens, NYC
May 26, 2005
  • May 26, 2005
I shouldve metnioned that when converting to 5 lug im putting in a new acle so I should be ok for seals. What bushings should I look at when im workin?
what should I do for torque boxes? btw my dads a professional welder so any steel fabrication is no problem.
luvmy88....I will be changin my filter....but I was askin more about chassis mods than maintenance.
stang22
1,318
Washington, D.C.
May 26, 2005
  • May 26, 2005
All of the bushings in the control arms, upper and lower. The upper control arm bushings that are located in the rear-end are a hassle to remove and replace sometimes. I would definately replace them, but dropping the rear-end is a piece of cake.
Tim
Car RamRod
Banned
Mar 30, 2005
623
Queens, NYC
May 26, 2005
  • May 26, 2005
whats the best way to buy those bushings? A kit or individual? And what brand....motorsport or an aftermarket?
thanks
stang22
1,318
Washington, D.C.
May 26, 2005
  • May 26, 2005
You definately want polyurethane. I believe you can buy the complete kit (Energy Suspension) for you car, but not sure how much it is. Autozone used to sell it, if not, Summit does.
Tim
Mavrick
2,264
Collingwood, ON
May 26, 2005
  • May 26, 2005
What cam are you running in that motor?
StreetStang302
103
New Jersey
May 26, 2005
  • May 26, 2005
Sub-Frame Connectors are always good.
Car RamRod
Banned
Mar 30, 2005
623
Queens, NYC
May 26, 2005
#10
  • May 26, 2005
  • #10
its got the stock 5.0 ho cam. I was considering going with an e303, but Im holding off for a year or so until I have enough to do the whole valvetrain right.
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Progress Thread 87 T-top slow progress
  • wobbyguy
  • Feb 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 10, 2025
nickyb
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
Fuel Spits sputter pops and bangs under load. Help wanted
  • sickntired
  • Mar 23, 2024
4K
Fox 5.0 Mustang Tech Apr 1, 2024
sickntired
