underide vs overide trac bars
BrownPSU78
129
What is the differance between underide and overide traction bars. Also sohuld these be installed at the same time as new rear leafs or should i let the springs settle a bit before installing.
--Brown
I agree , go with the under ride bars. Easier to install & work really well. You can install them when you put in the new springs. Settling does't affect them as they are attached to the lower plates.
over ride or under ride, the name says it all;
override, the bars run over the top of the rear axle and leaf springs, essentially creating a 4 link rear suspension.
underride bars run under the axle and leaf spring, operating more as a traction bar only in preventing wheel hop, and spring wind up.
for drag racing and the street, the underride bars are best, as they are easy to install.
for any other form of racing the override bars are best as they eliminate chassis lift, as well as reducing spring wrap. they are also more effective under braking than the override bars. the problem though is that they are more difficult to install, as oyu have to cut open the body to run them through, and they dont fit under the rear seat, so you have to replace it with the panel that shelby used in the gt-350's.
Rbohm nailed it.
To over simplify:
  • OVERRIDE - road racing is their specialty but they are the hardest to install.
  • UNDERRIDE - drag racing is their specialty, minor welding required (did not fit with my subframe connectors)
  • CALTRACS - most expensive but work better than the above and do not require any permanent modification to the car
Pathfinder65 said:
Cal tracs are expensive. Here's a possible solution though
http://hotrodsandhemis.com/Traction.html
I haven't made a set...yet, but they certainly look like a good alternative.
Dave :canada:
They are a good alternative. Made me a set. Cost me 120 bucks. 40 of it was from the 3/4in drill bit I had to buy that I didn't own, and another 20 for the tap I needed to buy to fix a problem created by the guy I payed 30 bucks to, to weld up a few things. He didn't listen to me and the alignment was off when he welded them. I was pulling consistant 1.69-1.72's on 26' et streets, and pulled many sub 1.6's on the bottle. Nothing has bent yet.
