Had Diablo for about 5 months now and the power has always been spotty. Great when the motor is cool, purely lethargic when the motor is hot. I am running max timing and wot fuel trim. Any ideas what may be causeing this?
Definately do not max the fuel to the lean side...that is crazy not knowing where you are at. If you leave the fuel as-is and max the timing you will be fine.
Timing will be all over the place regardless. Setting timing isn't as straight forward as just picking a number. The EEC is constantly changing timing based on ECT, ACT, load, and several other things.
I just didn't want you to be confused when you back it off and it is still al over the place.
