  • 2.3L (N/A & Turbo) Tech
Unstable Running
  • Thread starter Thread starter wingzero_ac19x
  • Start date Start date Sep 22, 2006
wingzero_ac19x
  • Sep 22, 2006
I have an 87 mustang 2.3 liter with 5 speed transmission. When it runs and warms up, the idle comes down like usual, but after a few minutes it starts to idle rough and begins to plummet back and forth, if you push the accelerator..it pretty much dies then will catch itself, or will just shut off. I have also noticed that when I turn things on like the heater and headlights, the volt guage drops and you can hear the fuel pump get weaker like it isnt getting suffecient power. I have changed TPS, ECM, battery cables, fuel pressure regulator, plugs, wires, starter relay, rotor cap and button, timing belt, egr valve, pvc valve, alternator, battery.... I dont know what else to try. I have been told it sounds like bad grounds.... but I dont even know where to start..any help would be appreciated...thanks
wingzero_ac19x
  • Sep 25, 2006
I found a couple more things out...after a code scan, it came up with 1. Fuel mixture too rich, and 2. EGR valve (code 31 I believe)... How do I adjust the fuel mixture? and can the EGR valve canister be cleaned out with carb and choke cleaner or do I have to buy a whole new assembly (I have already changed the EGR valve position Sensor).
J
1990 fox starts on starting fluid only
  • Jfox
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 15, 2026
AeroCoupe
Electrical Issues with my 2006 mustang gt
  • VerneVdV
  • May 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech May 22, 2026
VerneVdV
K
88 speed density misfire and bucking
  • kush
  • May 29, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
DadLife0724
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
