Engine UPDATED WITH FIX IN POST #49 Help with sputter issue with cold starts
I checked for vacuum leaks. I sprayed around the blower inlet, every connection to the throttlybody and around it. Then I sprayed the lower intake where it sits against the heads and front and rear of the block. I sprayed the upper to lower intakes and spacer. I sprayed along the vacuum three, the vacuum line into the fuel pressure regulator and brake booster. I never got ANY change in idle. Anyone have any other suggestions?
Ive been through the surge idle checklist. The symptoms I have dont really match with what I have read there.
So today I swapped O2s around. I drove the car for awhile, pretty hard. Ran codes again and got:
KOEO 67, 85, 10, 29 Continuous
KOER 41 AND 91
I hooked up a vacuum gauge at the tree in the A/C connection and get 7-8. At 2000 RPMs I get 14.
Im totally lost now
You have a vacuum leak... That would account for the 41/91 codes
Any idea how to find it? Im assuming this is the entire vacuum system. Id guess start running the lines down checking for cracks? Spray? Visual?
Finding vacuum leaks
Revised 6 May 2018 to add carbon canister plumbing as a common leak area.
There is no easy way to find vacuum leaks. It is a time consuming job that requires close inspection of each and every hose and connection.
Small vacuum leaks may not show much change using a vacuum gauge. The range of "good readings" varies so much from engine to engine that it may be difficult to detect small leaks. The engine in my first Mustang pulled about 16.5" of vacuum at 650-725 RPM, which I consider rather low. It was a mass market remanufactured rebuild, so no telling what kind of camshaft it had. Average readings seem to run 16"-18" inches at idle and 18"-21" at 1000 RPM. The only sure comparison is a reading taken when your car was performing at its best through all the RPM ranges and what it is doing now. Use one of the spare ports on the vacuum tree that is mounted on the firewall near the windshield wiper motor.
Use a squirt can of motor oil to squirt around the mating surfaces of the manifold & TB. The oil will be sucked into the leaking area and the engine will change speed. Avoid using flammable substitutes for the oil such as starting fluid, propane or throttle body cleaner. Fire is an excellent hair removal agent, and no eyebrows is not cool...
After you have done the simple visual checks and the check for vacuum leak on the underside of the intake manifold, consider doing a smoke test.
Some of the guys here have built smoke machines used to find automotive vacuum leaks. They seem to work quite well and are made mostly with parts you would have laying around in your garage. Check out smoke machine vacuum leak - YouTube and see if there is one that you could build.
The vacuum line plumbing is old and brittle on many of these cars, so replacing the lines with new hose is a good plan. The common 1/8” and ¼” vacuum hose works well and isn’t expensive.
The PCV grommet and the power brake booster check valve grommet are two places that often get overlooked when checking for vacuum leaks. The rubber grommets get hard and lose their ability to seal properly. The PVC grommet is difficult to see if it is correctly seated and fitting snugly.
The hoses and connections for the evaporative emissions (carbon canister and purge valve) are other common sources of vacuum leaks. The large vacuum outlets on the bottom side of the upper intake manifold are common hiding places for deteriorated vacuum lines and caps over unused vacuum ports.
Fuel injector O rings can get old and hard. When they do, they are prone to leaking once the engine warms up. This can be difficult to troubleshoot, since it is almost impossible to get to the injectors to squirt oil into the fuel injector mounting bosses. If the plastic caps on the fuel injectors (pintle caps) are missing, the O rings will slide off the injectors and fall into the intake manifold.
Fuel injector seal kits with 2 O rings and a pintle cap (Borg-Warner P/N 274081) are available at Pep Boys auto parts. Cost is about $3-$4 per kit. The following are listed at the Borg-Warner site ( http://www.borg-warner.com ) as being resellers of Borg-Warner parts:
http://www.partsplus.com/ or http://www.autovalue.com/ or http://www.pepboys.com/ or http://www.federatedautoparts.com/
Most of the links above have store locators for find a store in your area.
Use motor oil on the O rings when you re-assemble them & everything will slide into place. The gasoline will wash away any excess oil that gets in the wrong places and it will burn up in the combustion chamber. Heat the pintle caps in boiling water to soften them to make them easier to install.
Vacuum leak due to slipped lower intake manifold gasket...
Ask Nicoleb3x3 about the intake gasket that slipped out of place and caused idle and vacuum leak problems that could not be seen or found by external examination. I don't care what you spray with, you won't find the leak when it is sucking air from the lifter valley. It simply isn't possible to spray anything in there with the lower manifold bolted in place.
Determining if you have a leak due to a slipped intake gasket as shown above. This test is only good if you can get the engine to run somewhere in the 1000-1700 RPM range
If your valve cover oil filler & PVC systems are still in the original configuration, try this:
Cap or plug the hose from the intake manifold to the PVC valve with a bolt.
Cap or plug the PVC valve with a piece of hose with a plug or bolt in it.
At that point the only vent for the crankcase is the tube from the oil filler neck to the throttle body.
Disconnect the tube that runs from the oil filler neck to the throttle body. Make sure the oil filler cap is on securely. Start the engine and put your thumb over the end of the tube that comes from the oil filler cap. If you feel suction, there is a leak. Another thing to do is to extend the tubing from the filler neck so that there is enough to stick the end in a jar or cup filled with motor oil. If it sucks up the oil, you definitely have a leak at the underside of intake manifold.
This isn't necessarily the definitive test, but it is the best thing I could come up with on short notice. If there is a lot of blowby, this obviously won't be of much help.
See the picture below to see the breather tube where in connects to the throttle body. It is close to the TPS and runs over the top of the IAC.
The following are diagrams courtesy of Tmoss & Stang&2birds
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
Ignition switch wiring
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
I have had this issue for awhile. Since then, Ive had the lower intake redone, after I did it, do to a lower leak, crappy RTV job by me. Then I went with a Holley Systemax and had it redone after I again did a crappy RTV job on the lower. Based on the lower intake , that it has been done by me twice and a shop twice, I feel like odds are its an issue somewhere else since the issue has been consistent through four intake jobs
Im piecing together the parts for a smoke machine.
I read you force air in one side, very low pressure. Can anyone tell me how to adjust my compressor to push that low? Its a craftsman unit and I dont see settings or is there another way?
Thats crazy......But also very impressive. What do you think, is it the intake. Did you ever take the pressed caps off ??
Yeah, I'm not too happy. No, the intake was never jacked with at all. I can't understand why they would leak.
I guess if they won't warranty it out, I could take it to a welder and have someone weld them up... I don't know...
Those are just freeze plugs, if they will not warranty it all you gotta do is pop them dudes out and put some in with a smear of rtv, the part number is stamped on them. Well they should be at least.
Lol for the life of me I couldn't remember what those were... Damn I feel like I'm getting old.
I'll have to do a search and see what the heck they are there for...
Looks like a pretty big vacuum leak. That smoke machine works great huh? Hopefully fixing those leaks take car of your issue.
Drew
To be honest, I was so apprehensive about even trying to make the smoke machine. I was pulling my hair out because I was thinking how the hell do you make a smoke machine! Lol. Well after watching the video, I knew that was the best way to go about it. Man, I did it several times just because it was so cool!
Now, I'll research how to pop those puppies out to throw a bead of RTV and put them back in the correct way.
I believe they may be casting plugs but not sure, get the part number on them first to make sure you get replacements, they may be an odd size but I doubt it. Once you pop them out they are pretty much unusable.
