  • 1994 - 1995 Specific Tech
Upper and lower intake question
  • Thread starter Thread starter HighlyVenomous
  • Start date Start date Mar 29, 2004
H
HighlyVenomous
Jackson, Mississippi
Mar 29, 2004
  • Mar 29, 2004
I was wondering what the advantages and disadvantages would be to installing a Trick Flow STREET Heat upper and lower intake (summit part # 51500001) on a 94 cobra with 75mm MAF, 70mm throttle body, 24lb/hr injectors, and MAC fenderwell CAI. Any help would be greatly appreciated.
swingline
1,252
TCB - Taking Care of Business
Mar 29, 2004
  • Mar 29, 2004
Your Cobra intake is pretty good. You probably won't see any difference in an intake swap if you don't change out the heads. Also, I wouldn't go with a 70mm throttle body, 65mm will be plenty. Also I am pretty sure that your Cobra already has 24lb injectors. I may be wrong though....
ninety15.0
1,336
  • Mar 29, 2004
Yea i also dont think that you are going to see a big difference going from the cobra to the street heat. the cobra is a pretty good intake as is. I would also agree that a 70mm TB is a little big too. If you are doing H/C/I all at the same time...a different intake might be a better investment.
swingline
1,252
Mar 29, 2004
  • Mar 29, 2004
Even with new heads and cam, there are plenty of guys making good power with that intake. Just get it port-matched to the heads and you'll be OK.
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Wednesday at 10:20 AM
KRUISR
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
Gt40 e303 combo questions
  • 99mustanggt2018
  • Mar 30, 2025
1994 - 1995 Specific Tech Mar 30, 2025
KRUISR
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
