  • SN95 4.6L Mustang Tech
Upper Plenum ?'s
  • Thread starter Thread starter doorgunner26808
  • Start date Start date Jul 28, 2005
D
doorgunner26808
  • Jul 28, 2005
Is there a difference between the 96-98 GT upper plenums and the 99-04 plenums? For that matter is there andifference between the TB's as well? I know all about the 99 and up PI heads and intake, just curious about the Upper plenum and TB.
Thanks in advance.
-DG808
DropTopPony
Noob Slayer
2,570
south jersey
Jul 28, 2005
  • Jul 28, 2005
nope, they are interchangeable
D
doorgunner26808
  • Jul 28, 2005
Thanks for the reply. I know that they will bolt on any of the intakes, Just curious if Ford made any improvments to the 99 and newer ones.
-DG808
Premium Speed
1,006
Houston, Texas
Jul 28, 2005
  • Jul 28, 2005
-DG808
i believe the 99+ have a slightly larger inside diameter. i read this a while back but i have not measured to be sure.
Miles
1,225
Burlington, ON
Jul 28, 2005
  • Jul 28, 2005
The PCV valve connection into the upper intake on the front is a little different too btwn pree 99's and post 99's... so if you get a new upper intake, make sure it has both options (my accufab came with both)
02dragGT
23
Clarence Center, New York
Jul 28, 2005
  • Jul 28, 2005
Trick Flow comes with both also
J
Joel's98GT
368
central OH
Jul 29, 2005
  • Jul 29, 2005
the only real difference is the vacuum lines. I Port these things for people and have seen a a few different casting styles inside. some of the 96-97 styles have tiny vacuum/pcv lines and are a horrible design, most of them have a hump in the back, i've had a couple that didn't. but basicly they are the same.
lover
264
Atlanta, GA
Jul 29, 2005
  • Jul 29, 2005
I'm kind of just getting into the Mod motor. A 5.0 man you know. But I bought a ported plenum with a 70mmTB. I don't know what year Ford changed the size of the valve, I'm guessing it's the PCV, but his was a lot smaller than mine . I have an 02GT. I''m glad I had only taken a few bolts loose before I actually installed it and noticed it. Maybe someone with a more extensive 4.6 background can tell you what year the change occured.
BooWFO
991
Louisville, KY
Jul 29, 2005
  • Jul 29, 2005
You can use it just take a a smaller vaccum line put over the port on the plenum and inside the other vac line. That's what I did been working fine.
comatose
57
Columbus, Ohio
Jul 29, 2005
#10
  • Jul 29, 2005
  • #10
Per Modular Depot's plenum comparison test they stated: "In 2001 Ford changed the size of the PCV fitting on the plenums to a larger size."
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
Weber Carburetor tuning help
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
Engine Catch Can or not?
  • R82148V
  • Mar 4, 2026
Fox 5.0 Mustang Tech Mar 6, 2026
ctandc
C
Airaid reduction sleeve?
  • BriansNSane
  • Dec 20, 2025
SN95 4.6L Mustang Tech Dec 20, 2025
BriansNSane
